电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » [原创]H-JTAG发布V0.4.0版本
共4条 1/1 1 跳转至
2006-10-18 06:19:20     打赏
请到我的BLOG下载: http://twentyone.blogchina.com
1. Improve the support to ARM9E-S and ARM9EJ-S.
2. Add TAP configuration to support complex TAP/JTAG
3. Add the support for initialization script, which can be used for auto initialization
4. Add the programming of NOR flash and AT91SAM. But only a few chips are supported currently. I will upgrade H-Flasher to support more NOR flash chip step by step. The programming of AT91SAM chips may have some problem. I am looking for some boards for testing. I will correct the problem asap.
关键词: 原创     H-JTAG     发布     V0.4.0     版本
2006-10-19 01:16:00     打赏
越做越完善了,顶一个。
2006-10-30 22:32:00     打赏
謝謝了!!
2006-11-04 02:05:00     打赏
不错!!H-JTAG真是个好东西!!
共4条 1/1 1 跳转至
