TCP IP 源代码,请排队!!
TinyTcp Public Domain Release
The files in this release contain a simple implementation of TCP & FTP,
suitable for burning into ROM. It is, in effect, a big hack put together
in two or three days. It works for us, though, and you might like it,
too. We use it to boot our image processor by retrieving a load file
using the standard FTP server.
The code is intended to use the buffers from the Ethernet interface,
although shadow buffers could be hidden in the driver with no problem.
On one home-brew board here and didn't support byte-mode access to it.
Hence, the code takes pains to fool our local compiler into never
generating byte- or bit-mode instructions.
Since we have already burned the TCP into ROM, it is unlikely that
any further development will take place at IMAGEN. I would be willing
to act as a clearinghouse for future improvements to the code.
Warning: the code was intended for a 68000, and doesn't have
any byte swapping support in it. Shouldn't be too hard to add
if you want to run it on a little-endian machine.
Please note (and honor) the copyright on each file:
Copyright (C) 1986, IMAGEN Corporation
"This code may be duplicated in whole or in part provided that [1] there
is no commercial gain involved in the duplication, and [2] that this
copyright notice is preserved on all copies. Any other duplication
requires written notice of the author (Geoffrey H. Cooper)."
...in other words, do what you want with the code, but don't sell it and
give IMAGEN and me credit on whatever you produce. If you develop a product
based on this code and want to sell it, give me a call and I'll be reasonable.
This code is distributed "as is." Neither the author nor IMAGEN Corporation
guarantees that it works or meets any particular specifications. The act
of distributing this software does not represent a commitment by either the
author nor IMAGEN Corporation to provide maintenance or consulting services
related to this software.
But feel free to ask me any questions that you can't answer for yourself.
- Geof Cooper
Imagen Corporation
(408)986 9400
[imagen!geof@decwrl.dec.com, {decwrl,saber}!imagen!geof]
April 16, 1986
The package requires some system support:
clock_ValueRough() - should be a procedure that returns the current
value of a millisecond clock. The procedure is called frequently,
so that interrupts are not needed to service the clock. Our
implementation polls the real time timer and assumes that it is
called frequently enough so that it doesn't miss clock ticks (Since
the timer is only used for network timeouts, it doesn't really matter
if it does miss clock ticks, of course). Systems without a clock
could probably get by with a procedure that increments a static
variable and returns it, by adjusting the timeout constants in the
program.
Network driver - some network interface driver is needed. A driver for a
3Com multibus (ethernet) board is included; this board isn't made
anymore (at least not by 3Com, there are still compatible boards
being made, but I don't know of any being popularly distributed),
so you'll probably need to write a driver for the board in your system.
Guide to source files:
sed.c - Simple Ethernet Driver - Driver for 3Com multibus card. If you
have another type of Ethernet board, you can use this driver as
a template.
sed.h - header file for the above.
arp.c - Implementation of Address Resolution Protocol. Note that there
is no arp "mapping" per se. The higher level code (tcp, in this
case) is required to keep track of internet and ethernet addresses.
tinytcp.c - Implementation of TCP.
tinytcp.h - Header file for above, and for everything else.
tinyftp.c - Implementation of FTP, only allows files to be retrieved,
not sent.
[em27]
关键词: 源代码 排队
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
汽车+汽车电子电阻解释与分析被打赏5分 | |
分享汽车通信和多媒体总线结构被打赏20分 | |
【我踩过的那些坑】结构堵孔导致的喇叭无声问题被打赏50分 | |
NUCLEO-U083RC学习历程38+串口通过队列的方式输出两个字符串被打赏20分 | |
【我踩过的那些坑】分享一下调试一款AD芯片的遇到的“坑”被打赏50分 | |
电流检测模块MAX4080S被打赏10分 | |
分享电控悬架的结构与工作原理(一)被打赏20分 | |
多组DCTODC电源方案被打赏50分 | |
【我踩过的那些坑】STM32cubeMX软件的使用过程中的“坑”被打赏50分 |
