共3条
LCD 帮我看看LCD为什么没显示
问
128×64的LCD屏,搞了一天了,写了个简单的测试程序,大家帮我看看是不是程序的问题,实在是想不到什么会出问题。
#include "config.h"
//LCD Interface
#define LCD_DB P0
sbit sbLCD_E = P2^4; // LCD使能
sbit sbLCD_RW = P2^6; // 1-读,0-写
sbit sbLCD_RS = P2^7; // 1-数据,0-指令
sbit sbLCD_CS1 = P2^3; // 左半屏使能
sbit sbLCD_CS2 = P2^2; // 右半屏使能
uint8 code hanzi[][16]={
//*取子方式:纵向,字节倒序*//
/*-- 文字: 正 --*/
{0x00,0x02,0x02,0xC2,0x02,0x02,0x02,0x02,0xFE,0x82,0x82,0x82,0x82,0x82,0x02,0x00},// 0
{0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x00},// 1
/*-- 文字: 确 --*/
{0x00,0x84,0xE4,0x5C,0x44,0xC4,0x10,0xF8,0x97,0x92,0xF2,0x9A,0x96,0xF2,0x00,0x00},// 2
{0x01,0x00,0x3F,0x08,0x88,0x4F,0x30,0x0F,0x04,0x04,0x3F,0x44,0x84,0x7F,0x00,0x00},// 3
// 短延时
void Delay10ns(void)
uint8 i;
for(i=0; i<10; i++)
_nop_();
_nop_();
// 长延时
void Delay100ms(void)
uint8 i = 0x50;
uint8 j;
do
i--;
j=0xFD;
do
_nop_();
_nop_();
j--;
}while(j);
}while(i);
// 等待左
void Wait1(void)
uint8 readstatus;
LCD_DB=0xFF; // P0口写1,确保输入数据的正确性
sbLCD_CS1 = 1;
sbLCD_CS2 = 0;
sbLCD_RW = 1;
sbLCD_RS = 0;
sbLCD_E = 1;
do
readstatus = LCD_DB; // 读状态
_nop_();
_nop_();
while (readstatus & 0x80); // 若bit7不为0,则一直读状态
// 等待右
void Wait2(void)
uint8 readstatus;
P0=0xFF;
sbLCD_CS1 = 0;
sbLCD_CS2 = 1;
sbLCD_RW = 1;
sbLCD_RS = 0;
sbLCD_E = 1;
do
_nop_();
_nop_();
// 写左命令
void W_Com1(uint8 com)
Wait1();
sbLCD_RW = 0;
sbLCD_RS = 0;
LCD_DB = com;
sbLCD_E = 1; // 下降沿
Delay10ns();
sbLCD_E = 0;
// 写右命令
void W_Com2(uint8 com)
Wait2();
sbLCD_RW = 0;
sbLCD_RS = 0;
LCD_DB = com;
sbLCD_E = 1;
Delay10ns();
sbLCD_E = 0;
// 写左数据
void W_Dat1(uint8 dat)
Wait1();
sbLCD_RW = 0;
sbLCD_RS = 1;
LCD_DB = dat;
sbLCD_E = 1;
Delay10ns();
sbLCD_E = 0;
// 写右数据
void W_Dat2(uint8 dat)
Wait2();
sbLCD_RW = 0;
sbLCD_RS = 1;
LCD_DB = dat;
sbLCD_E = 1;
Delay10ns();
sbLCD_E = 0;
// 定点纵向写一字节
// yPos为页寄存器地址(0-7)
// xPos为列(0-63)
void SetPos(uint8 yPos, uint8 xPos, uint8 value)
yPos &= 0x07; // yPos低3位有效
yPos += 0xB8; // B8为页起始地址设置
if (xPos <= 63)
xPos &= 0x3F; // xPos低6位有效
xPos |= 0x40; // 列起始地址设置
W_Com1(xPos);
W_Com1(yPos);
W_Dat1(value);
else
xPos &= 0x3F;
xPos |= 0x40;
W_Com2(xPos);
W_Com2(yPos);
W_Dat2(value);
// 全屏填充
void Fulfill(uint8 value)
uint8 xPos;
uint8 yPos;
yPos = 0;
do
xPos = 0;
do
SetPos(yPos, xPos, value);
xPos += 1;
if (xPos == 128)
xPos = 0;
while (xPos);
yPos &= 0x07;
yPos += 1;
if (yPos == 0x08)
yPos = 0;
while (yPos);
// 显示一16×16汉字
// type为非0时,显示16×16汉字
// yPos为第几行(0—7)
// xPos为第几列(0-63)
// value 为字模的序号
void Display_Data(uint8 type, uint8 yPos, uint8 xPos, uint8 value)
uint8 a;
uint8 b;
uint8 i = 0;
xPos *= 8;
yPos *= 2;
if (type) // 写汉字
for (a=0; a<2; a++) // 写上半部分,每个汉字2行
for (b=0; b<16; b++) // 写横向
SetPos(yPos, xPos, hanzi[value][i]);
i++;
xPos++;
xPos -= 16; //写一行起始地址
yPos++;
yPos -= 2; // 下一个字的起始地址
xPos += 16;
value += 1;
void main(void)
uint8 i;
for (i=0; i<10; i++)
Delay100ms();
Fulfill(0x00); // 清屏
Delay100ms();
Display_Data(1, 0, 0, 2); // 在第0行第0列写汉字“确”
答 1: 自己顶个先~ 答 2: ~~~~~~~ 答 3: .会不会也是IO驱动问题?改成强推挽试试。 答 4: 测试时最好确保LCD引脚的接触是正常的 答 5: rt引脚接触都是正常的,也找人帮哦检查了下~
I0用P0也接了10K的上拉电阻了 答 6: 可以找厂家要一段测试程序的,一般他们都有我就试过这样的事情后来发觉还是程序问题,早点找他要就早点知道原因拉 答 7: 有个RST引脚要接高,或用IO控制下试试
#include "config.h"
//LCD Interface
#define LCD_DB P0
//*取子方式:纵向,字节倒序*//
/*-- 文字: 正 --*/
/*-- 文字: 确 --*/
// 短延时
uint8 i;
for(i=0; i<10; i++)
_nop_();
_nop_();
// 长延时
uint8 i = 0x50;
uint8 j;
do
i--;
j=0xFD;
do
_nop_();
_nop_();
j--;
}while(j);
}while(i);
// 等待左
void Wait1(void)
uint8 readstatus;
sbLCD_CS1 = 1;
sbLCD_CS2 = 0;
sbLCD_RW = 1;
sbLCD_RS = 0;
sbLCD_E = 1;
do
_nop_();
_nop_();
// 等待右
void Wait2(void)
uint8 readstatus;
P0=0xFF;
sbLCD_CS1 = 0;
sbLCD_CS2 = 1;
sbLCD_RW = 1;
sbLCD_RS = 0;
sbLCD_E = 1;
do
_nop_();
_nop_();
// 写左命令
Wait1();
sbLCD_RW = 0;
sbLCD_RS = 0;
LCD_DB = com;
sbLCD_E = 1; // 下降沿
Delay10ns();
sbLCD_E = 0;
// 写右命令
Wait2();
sbLCD_RW = 0;
sbLCD_RS = 0;
LCD_DB = com;
sbLCD_E = 1;
Delay10ns();
sbLCD_E = 0;
// 写左数据
Wait1();
sbLCD_RW = 0;
sbLCD_RS = 1;
LCD_DB = dat;
sbLCD_E = 1;
Delay10ns();
sbLCD_E = 0;
// 写右数据
Wait2();
sbLCD_RW = 0;
sbLCD_RS = 1;
LCD_DB = dat;
sbLCD_E = 1;
Delay10ns();
sbLCD_E = 0;
// 定点纵向写一字节
// yPos为页寄存器地址(0-7)
// xPos为列(0-63)
if (xPos <= 63)
W_Com1(xPos);
W_Com1(yPos);
W_Dat1(value);
else
xPos &= 0x3F;
xPos |= 0x40;
W_Com2(xPos);
W_Com2(yPos);
W_Dat2(value);
// 全屏填充
uint8 xPos;
uint8 yPos;
yPos = 0;
do
xPos = 0;
do
xPos += 1;
if (xPos == 128)
xPos = 0;
while (xPos);
yPos &= 0x07;
yPos += 1;
if (yPos == 0x08)
yPos = 0;
while (yPos);
// 显示一16×16汉字
// yPos为第几行(0—7)
// xPos为第几列(0-63)
// value 为字模的序号
uint8 a;
uint8 b;
uint8 i = 0;
xPos *= 8;
yPos *= 2;
if (type) // 写汉字
i++;
xPos++;
yPos++;
xPos += 16;
value += 1;
void main(void)
uint8 i;
Delay100ms();
Delay100ms();
共3条
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
