共3条
AVRGCC AVRGCC中如何使用浮点数
问
我在使用winAVR GCC时遇到这样一个问题
我定义了一个变量:
volatile double a1;
if(CANsu5!=0) a1=1900./CANsu5;
而在编译时总是有一个错误
AVR-gcc -g -Wall -O2 -mmcu=atmega8515 -Wl,-Map,max525.map -o max525.elf max525.o
C:\WinAVR\bin\..\lib\gcc-lib\AVR\3.3.1\..\..\..\..\AVR\bin\ld.exe:
region text is full(max525.elf section .text)
make:***[max525.elf]error 1;
当把这个浮点数定义为整形时如LONG就没问题,不知为何.
我估计是我的MAKE文件不对
以下是我的Makefile:
PRG = max525
OBJ = max525.o
MCU_TARGET = atmega8515
OPTIMIZE = -O2
DEFS =
LIBS =
# You should not have to change anything below here.
CC = AVR-gcc
# Override is only needed by AVR-lib build system.
override CFLAGS = -g -Wall $(OPTIMIZE) -mmcu=$(MCU_TARGET) $(DEFS)
override LDFLAGS = -Wl,-Map,$(PRG).map
OBJCOPY = AVR-objcopy
OBJDUMP = AVR-objdump
all: $(PRG).elf lst text eeprom
$(PRG).elf: $(OBJ)
$(CC) $(CFLAGS) $(LDFLAGS) -o $@ $^ $(LIBS)
clean:
rm -rf *.o $(PRG).elf *.eps *.png *.pdf *.bak
rm -rf *.lst *.map $(EXTRA_CLEAN_FILES)
lst: $(PRG).lst
%.lst: %.elf
$(OBJDUMP) -h -S $< > $@
# Rules for building the .text rom images
text: hex bin srec
hex: $(PRG).hex
bin: $(PRG).bin
srec: $(PRG).srec
%.hex: %.elf
$(OBJCOPY) -j .text -j .data -O ihex $< $@
%.srec: %.elf
$(OBJCOPY) -j .text -j .data -O srec $< $@
%.bin: %.elf
$(OBJCOPY) -j .text -j .data -O binary $< $@
# Rules for building the .eeprom rom images
eeprom: ehex ebin esrec
ehex: $(PRG)_eeprom.hex
ebin: $(PRG)_eeprom.bin
esrec: $(PRG)_eeprom.srec
%_eeprom.hex: %.elf
$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O ihex $< $@
%_eeprom.srec: %.elf
$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O srec $< $@
%_eeprom.bin: %.elf
$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O binary $< $@
# Every thing below here is used by AVR-libc's build system and CAN be ignored
# by the casual user.
FIG2DEV = fig2dev
EXTRA_CLEAN_FILES = *.hex *.bin *.srec
dox: eps png pdf
eps: $(PRG).eps
png: $(PRG).png
pdf: $(PRG).pdf
%.eps: %.fig
$(FIG2DEV) -L eps $< $@
%.pdf: %.fig
$(FIG2DEV) -L pdf $< $@
%.png: %.fig
$(FIG2DEV) -L png $< $@
请各位高手指点一下,谢谢! 答 1: 搞定了就是MAKEFILE的问题,用沈文书上的MAKEFILE试了一下就行了 答 2: 要链接浮点库要链接浮点库
我定义了一个变量:
volatile double a1;
而在编译时总是有一个错误
我估计是我的MAKE文件不对
以下是我的Makefile:
PRG = max525
OBJ = max525.o
OPTIMIZE = -O2
DEFS =
LIBS =
CC = AVR-gcc
$(PRG).elf: $(OBJ)
clean:
lst: $(PRG).lst
%.lst: %.elf
text: hex bin srec
hex: $(PRG).hex
bin: $(PRG).bin
srec: $(PRG).srec
%.hex: %.elf
%.srec: %.elf
%.bin: %.elf
%_eeprom.hex: %.elf
%_eeprom.bin: %.elf
FIG2DEV = fig2dev
dox: eps png pdf
eps: $(PRG).eps
png: $(PRG).png
pdf: $(PRG).pdf
%.eps: %.fig
%.pdf: %.fig
%.png: %.fig
共3条
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
