Interface,Threshold,Voltage,Levels 接口电路门限电平Interface Threshold Voltage Levels
问
Comparison of Input and Output [I/O] logic switching levels for the CMOS [5V], PECL [5V], RS422/485, RS232, LVDS, BTL, GTL logic families.
The graph above provides a comparison between the Input and Output [I/O] logic switching levels for a few different Interface bus types.
The output logic levels above are defined by the Terms section below. For a review of Noise Margin numbers and a short description of many
of the IC logic families , refer to the Logic Family Selection page. A graph for Low Voltage [LV] devices resides on the LV Logic Threshold page.
An additional chart of Standard Logic Voltage levels is provided on the Logic Threshold Voltage Levels page
Terms -
VCC: The voltage applied to the power pin(s). In most cases the voltage the device needs to operate at.
VIH: [Voltage Input High] The minimum positive voltage applied to the input which will be accepted by the device as a logic high.
VIL: [Voltage Input Low] The maximum positive voltage applied to the input which will be accepted by the device as a logic low.
VOL: [Voltage Output Low] The maximum positive voltage from an output which the device considers will be accepted as the maximum positive low level.
VOH: [Voltage Output High] The maximum positive voltage from an output which the device considers will be accepted as the minimum positive high level.
VT: [Threshold Voltage] The voltage applied to a device which is "transition-Operated", which cause the device to switch. May also be listed as a '+' or '-' value.
Description of TTL, ECL and CMOS Glue Logic Families
Device Families:
TTL (74xx) True TTL
74L Low power
74S Schottky
74H High speed
74LS Low power - Schottky
74AS Advanced - Schottky
74ALS Advanced - Low power - Schottky
74F(AST) Fast - (Advanced - Schottky)
74C CMOS...................check Vcc levels
74HC (U) High speed - CMOS (Unbuffered output)
74HCT High speed - CMOS - TTL inputs
74AHC Advanced - High speed - CMOS
74AHCT Advanced - High speed - CMOS - TTL inputs
74FCT (-A) Fast - CMOS - TTL inputs (speed variations)
74FCT (-T, -AT) Fast - CMOS - TTL inputs (speed variations)
74AC Advanced - CMOS
74ACT Advanced - CMOS - TTL inputs
74FACT AC, ACT (Q) series
74ACQ Advanced - CMOS - Quiet outputs
74ACTQ Advanced - CMOS - TTL inputs - Quiet outputs
Bus Driver Families
74ABT Advanced - BiCMOS - Technology
74ABTE ABT - Enhanced Transceiver Logic
74ABTH Advanced - BiCMOS - Technology - bus Hold
74BCT BiCMOS - TTL inputs
74BTL Backplane - Transceiver - Logic
74GTL Gunning - Transceiver - Logic
74GTLP GTL Plus
Low Voltage Families
74ALB Advanced - Low Voltage - BiCMOS
74LV (U) Low - Voltage (Unbuffered output)
74LVC (R) (U) LV - CMOS (damping Resistor)(Unbuffered output)
74LVCH Low - Voltage - CMOS - bus Hold
74ALVC Advanced - Low - Voltage - CMOS
74LVT (R) (U) LV - TTL (damping Resistor(Unbuffered output)
74LVTZ Low - Voltage - TTL - High Impedance power-up
74ALVC (R) ALV - CMOS (bus Hold) (damping Resistor)
74ALVCH Advanced - Low - Voltage - CMOS - bus Hold
74LCX LV - CMOS (operates with 3v & 5v supplies)
74VCX LV - CMOS (operates with 1.8v & 3.6v supplies
4000 True CMOS (non-TTL levels)
ECL Device Families:
MEC I 8nS*
MEC II 2nS*
MEC III (16XX) 1nS* .......* = Rise & Fall Times
101xx 100 series 10K ECL, 3.5nS*
102xx 200 series 10K ECL, 2.5nS*
108xx 800 series 10K ECL, voltage compensated, 3.5nS*
10Hxxx 10K - High speed, voltage compensated, 1.8nS*
10Exxx 10K - ECLinPS, voltage compensated, 800pS*
100xxx 100K, temperature compensated
100Hxxx 100K - High speed, temperature compensated
100Exxx 100K - ECLinPS, temp, voltage comp., 800pS*
Design Key words for this page: Glue Logic Families, CMOS, TTL, ECL, Speed, IC, Integrated Circuits, Propagation delay, Logic Types, logic switching levels, Output voltage, Low-Voltage, Threshold Voltage, 74xx, 74AC00, 74HC, 74AHC00, Description, Digital Logic, Definition for Logic family, Logic Terms, TTL: Transistor Transistor Logic, ECL: Emitter Coupled Logic, CMOS: Complementary Metal-Oxide Semiconductor, BICMOS: Bipolar Complementary Metal Oxide Semiconductor 答 1: 图中RS-422和RS-485的部分对吗?
Terms -
Device Families:
TTL (74xx) True TTL
74L Low power
74S Schottky
74H High speed
Bus Driver Families
74GTLP GTL Plus
MEC I 8nS*
MEC II 2nS*
