共4条
请高手帮忙改写(汇编转C语言)
问
以下是一款手机液晶屏的汇编驱动程序,实在看不懂,哪位大侠帮忙给改成汇编的吧!只要提出其中的wr_cmd(),wr_data(),disp_bmp(unsigned char x,unsigned char y)就可以。谢谢!
CS1 bit p1.2
RESET bit P1.5
RS bit P1.0
E_RD bit P1.4
WR_RW bit P1.1
CR EQU 54H
CR_BACK EQU 53H
ORG 0000H
START:
CLR E_RD
MOV CR,#10H ;096B01 #013h is currect
CLR CS1
CLR RESET ;initalization
LCALL DELAY
SETB RESET
MOV A,#0E2H ;initialize interal function
LCALL WCOM ;write interal reset
LCALL DELAY
MOV A,#02CH ;power control(VB,VR,VF=1,1,1)
LCALL WCOM
LCALL DELAY
MOV A,#02EH ;power control(VB,VR,VF=1,1,1)
LCALL WCOM
LCALL DELAY
MOV A,#02FH ;power control(VB,VR,VF=1,1,1)
LCALL WCOM
MOV A,#025H ;096B01 23h is currect ;Regulator resistor select 110
LCALL WCOM
; MOV A,#0A3H ;set LCD bias=1/9
; LCALL WCOM
MOV A,#081H ;set reference voltage mode
LCALL WCOM
MOV A,CR ;bbg 2F ;set reference voltage
LCALL WCOM
MOV A,#0C8H ;set SHL COM1 to COM64 start page setup
LCALL WCOM
MOV A,#0A0H ;ADC select SEG1 to SEG132
LCALL WCOM
MOV A,#040H ;Initial Display Line was first line
LCALL WCOM
MOV A,#0A6H ;set nomal display
LCALL WCOM
MOV A,#0AFH ;set display ON
LCALL WCOM
MAIN:
MOV DPTR,#SUCCESS
LCALL DISPLAY
;LCALL ICON
LCALL WAITKEY
MOV DPTR,#TAB4
LCALL DISPLAY
;LCALL ICON
LCALL WAITKEY
MOV R3,#00H
LCALL TEST
MOV R3,#06
LCALL TEST
MOV R3,#012
LCALL TEST
MOV R3,#012H
LCALL TEST
MOV R3,#018H
LCALL TEST
; MOV R3,#01EH
; LCALL TEST
MOV R3,#024H
LCALL TEST
MOV R3,#06H
; LCALL CR_INCREASE
LCALL TEST
MOV R3,#0CH
; LCALL CR_INCREASE
LCALL TEST
;LCALL CLEAR
;LCALL WAITKEY
; LCALL ICON
LJMP START
ICON:
LCALL CLEAR
MOV A,#0B8H ;page8
LCALL WCOM
MOV A,#017H ;column address high 4 bits
LCALL WCOM
MOV A,#03H ;column addrress low 4 bits
LCALL WCOM
MOV R0,#132
ICON1:
MOV A,#0ffH
LCALL WDATA
;LCALL ICONDISP
LCALL WAITKEY
LCALL WAIT
DJNZ R0,ICON1
RET
ICONDISP:
LCALL CLEAR
MOV A,#0B6H
LCALL WCOM
MOV A,#010H
LCALL WCOM
MOV A,#00H
LCALL WCOM
LCALL WDATA
LCALL WAIT
RET
CLEAR:
MOV R2,#0B0H ;page0
MOV A,R2
CLEAR2:
MOV A,R2
LCALL WCOM
MOV A,#010H ;
LCALL WCOM
MOV A,#00H ;static indicator off
LCALL WCOM
MOV R0,#128
CLEAR1:
MOV A,#00
LCALL WDATA
DJNZ R0,CLEAR1
INC R2
CJNE R2,#0B9H,CLEAR2 ;clear all 9 pages
RET
CR_INCREASE:
MOV A,CR
ADD A,#13H
MOV CR,A
RET
CR_RECOVER:
MOV CR,#015H
RET
CONTRAST:
BEGIN:
KEY2:
MOV A,#081H ;REFERENCE VOLTAGE SELECT
LCALL WCOM
MOV A,CR ;REFERENCE VOLTAGE PARAMETER:32 3F
LCALL WCOM
SETB P3.1
MOV C,P3.1
MOV 44H,#015
DELAY_20MS:
LCALL DELAY
DJNZ 44H,DELAY_20MS
JC KEY1
INC CR
LCALL WCOM
LCALL WCOM
KEY1:
SETB P3.2
MOV C,P3.2
JC CR_END
DEC CR
LCALL WCOM
LCALL WCOM
CR_END:
LCALL DELAY
SETB P3.7
MOV C,P3.7
JNC NEXT
LJMP BEGIN
NEXT:
MOV 44H,#015
NEXT1: LCALL DELAY
DJNZ 44H,NEXT1
RET
TEST:
MOV R2,#0B0H
TEST2: MOV A,R2 ;set page address
LCALL WCOM
MOV A,#010H ;set column address MSB
LCALL WCOM
MOV A,#00H ;set column address LSB
LCALL WCOM
MOV R1,#22 ;set (6*8)*17characters
TEST1: MOV DPTR,#CHAR
MOV R0,#06H
TEST0:
MOV A,R3
MOVC A,@A+DPTR
LCALL WDATA
INC DPTR
DJNZ R0,TEST0
DJNZ R1,TEST1
INC R2
CJNE R2,#0B9H,TEST2
LCALL DELAY
LCALL WAITKEY
RET
DISPLAY:
MOV R2,#0B0H
DISPLAY0:
MOV A,R2
LCALL WCOM
DISPLAY1:
LCALL WCOM
LCALL WCOM
MOV R0,#128
DISPLAY2:
MOV A,#0
MOVC A,@A+DPTR
LCALL WDATA
INC DPTR
DJNZ R0,DISPLAY2
INC R2
CJNE R2,#0B9H,DISPLAY0
LCALL CONTRAST
RET
EXCHANGE:PUSH B
CLR C
RLC A
MOV B.0,C
RLC A
MOV B.1,C
RLC A
MOV B.2,C
RLC A
MOV B.3,C
RLC A
MOV B.4,C
RLC A
MOV B.5,C
RLC A
MOV B.6,C
RLC A
MOV B.7,C
MOV A,B
POP B
RET
SMAP: MOV R5,#18H ;TEST 6
SMAP4: LCALL DELAY
DJNZ R5,SMAP4
SMAP3: MOV R4,#00H
MOV R1,#40H
SMAP1: MOV A,#40H
ORL A,R4
LCALL WCOM
LCALL DELAY
INC R4
MOV P3,#0FFH
MOV 67H,#08H
SMAP5: LCALL DELAY
DJNZ 67H,SMAP5
MOV C,P3.7
JNC SMAP2
LCALL DELAY
MOV C,P3.7
JNC SMAP2
DJNZ R1,SMAP1
LJMP SMAP3
SMAP2: LCALL DELAY
MOV A,#40H
LCALL WCOM
RET
;SELECT SUBPROGRAM
WAITKEY:SETB P3.7
MOV 43H,#80
WAITKEY1:
LCALL DELAY ;IN ORDER TO ACCEPT SELECT STATUS
DJNZ 43H,WAITKEY1
STATUS: MOV C,P3.7
JC STATUS
RET
WAIT: MOV 42,#2FH
WAIT0: LCALL DELAY
DJNZ 42,WAIT0
RET
;DELAY SUBPROGRAM
DELAY: MOV 40H,#032H ;10.05ms
DELAY1: MOV 41H,#030H
DELAY2: DJNZ 41H,DELAY2 ;192us
DJNZ 40H,DELAY1
RET
WCOM:
CLR CS1
CLR RS
CLR WR_RW
LJMP TRANSMIT
WDATA:
CLR CS1
SETB RS
CLR WR_RW
; CLR WR_RW
TRANSMIT:
CLR E_RD
; NOP
;SETB E_RD
MOV P2,A
NOP
NOP
NOP
NOP
SETB E_RD
NOP
NOP
NOP
nop
CLR E_RD
; SETB CS1
RET
CHAR:
DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
DB 0AAH,0AAH,0AAH,0AAH,0AAH,0AAH
DB 055H,055H,055H,055H,055H,055H
DB 0FFH,000H,0FFH,000H,0FFH,000H
DB 000H,0FFH,000H,0FFH,000H,0FFH
; DB 024H,054H,0FEH,054H,048H,000H ;$
DB 048H,054H,054H,054H,024H,000H ;$
; DB 032H,049H,079H,041H,03EH,000H ;G
DB 03EH,041H,079H,049H,032H,000H ;G
SUCCESS:
;-- 调入了一幅图像:D:\test\ICON\ICON.bmp --
;-- 宽度x高度=128x64 --
DB 0FFH,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H
DB 01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H
DB 01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,01H,0FFH
DB 0FFH,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H
DB 00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H
DB 00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,0FFH
DB 00H,00H,0C0H,0F8H,0FFH,1FH,0FFH,0F8H,0C0H,00H,00H,00H,00H,0FFH,0FFH,0FFH
DB 0FEH,0F0H,0F0H,0FEH,0FFH,0FFH,0FFH,00H,00H,00H,0C0H,0F8H,0FFH,1FH,0FFH,0F8H
DB 0C0H,00H,00H,00H,01H,07H,1FH,3FH,0FCH,0F0H,0FCH,3FH,0FH,07H,01H,00H
DB 00H,0FFH,0FFH,0FFH,0F0H,0F8H,0FCH,8EH,07H,03H,01H,00H,00H,0FFH,0FFH,0FFH
DB 41H,41H,41H,41H,41H,01H,00H,00H,00H,0FFH,0FFH,0FFH,81H,81H,81H,0C3H
DB 0FFH,7EH,3CH,00H,00H,0F8H,0FEH,0FFH,07H,01H,01H,07H,0FFH,0FEH,0F8H,00H
DB 30H,3EH,3FH,0FH,03H,02H,03H,0FH,3FH,3EH,30H,00H,00H,3FH,3FH,3FH
DB 0FH,3FH,3FH,0FH,3FH,3FH,3FH,00H,30H,3EH,3FH,0FH,03H,02H,03H,0FH
DB 3FH,3EH,30H,00H,20H,38H,3CH,3FH,0FH,03H,0FH,1FH,3CH,38H,20H,00H
DB 00H,3FH,3FH,3FH,00H,01H,07H,1FH,3EH,38H,20H,00H,00H,3FH,3FH,3FH
DB 20H,20H,20H,20H,20H,20H,00H,00H,00H,3FH,3FH,3FH,00H,00H,00H,00H
DB 00H,00H,00H,00H,00H,07H,1FH,3FH,38H,20H,20H,38H,3FH,1FH,07H,00H
DB 00H,0E0H,0E0H,0E0H,20H,20H,60H,0E0H,0C0H,80H,00H,00H,00H,00H,00H,00H
DB 0E0H,0E0H,0E0H,00H,00H,00H,00H,00H,00H,80H,0C0H,0E0H,60H,20H,20H,60H
DB 0E0H,0C0H,80H,00H,00H,0E0H,0E0H,0E0H,20H,20H,20H,60H,0E0H,0C0H,80H,00H
DB 00H,0E0H,0E0H,0E0H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H
DB 0E0H,0E0H,0E0H,00H,00H,00H,00H,00H,20H,0E0H,0E0H,0E0H,80H,00H,80H,0E0H
DB 0E0H,0E0H,20H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H
DB 00H,0FFH,0FFH,0FFH,00H,00H,00H,00H,0FFH,0FFH,0FFH,00H,00H,00H,00H,00H
DB 0FFH,0FFH,0FFH,00H,00H,00H,00H,00H,00H,0C3H,0C7H,0CFH,0CH,18H,10H,30H
DB 0F0H,0E0H,0C0H,00H,00H,0FFH,0FFH,0FFH,10H,10H,10H,18H,1FH,0FH,07H,00H
DB 00H,0FFH,0FFH,0FFH,00H,00H,00H,00H,00H,00H,00H,00H,00H,0C0H,0F8H,0FFH
DB 7FH,43H,7FH,0FFH,0F8H,0C0H,00H,00H,00H,00H,03H,0FH,0FFH,0FEH,0FFH,0FH
DB 03H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H
DB 00H,07H,07H,07H,04H,04H,06H,07H,03H,01H,00H,00H,00H,00H,00H,00H
DB 07H,07H,07H,00H,00H,00H,00H,00H,00H,01H,03H,07H,06H,04H,04H,06H
DB 07H,03H,01H,00H,00H,07H,07H,07H,00H,00H,00H,00H,00H,00H,00H,00H
DB 00H,07H,07H,07H,04H,04H,04H,04H,04H,04H,04H,00H,06H,07H,07H,01H
DB 00H,00H,00H,01H,07H,07H,06H,00H,00H,00H,00H,00H,07H,07H,07H,00H
DB 0FFH,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H
DB 80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H
DB 80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,80H,0FFH
TAB4:;-- 调入了一幅图像:C:\Documents and Settings\zhangwenying\桌面\program(可改)\247画面\行特殊短路画面.bmp --
;-- 调入了一幅图像:F:\F-disk\My Documents\My PICtures\nt7532-2.bmp --
;-- 宽度x高度=128x64 --
DB 000H,000H,000H,000H,000H,000H,000H,000H,0F8H,048H,048H,048H,048H,048H,048H,0F8H
DB 000H,000H,000H,000H,000H,000H,000H,0F8H,048H,048H,048H,048H,048H,048H,0F8H,000H
DB 000H,000H,000H,000H,000H,000H,0F8H,048H,048H,048H,048H,048H,048H,0F8H,000H,000H
DB 000H,000H,000H,000H,000H,0F8H,048H,048H,048H,048H,048H,048H,0F8H,000H,000H,000H
DB 000H,000H,000H,000H,0F8H,048H,048H,048H,048H,048H,048H,0F8H,000H,000H,000H,000H
DB 000H,000H,000H,0F8H,048H,048H,048H,048H,048H,048H,0F8H,000H,000H,000H,000H,000H
DB 000H,000H,0F8H,048H,048H,048H,048H,048H,048H,0F8H,000H,000H,000H,000H,000H,000H
DB 000H,0F8H,048H,048H,048H,048H,048H,048H,0F8H,000H,000H,000H,000H,000H,000H,000H
DB 000H,000H,000H,000H,000H,080H,040H,030H,00FH,004H,004H,004H,004H,044H,084H,07FH
DB 000H,000H,000H,000H,080H,040H,030H,00FH,004H,004H,004H,004H,044H,084H,07FH,000H
DB 000H,000H,000H,080H,040H,030H,00FH,004H,004H,004H,004H,044H,084H,07FH,000H,000H
DB 000H,000H,080H,040H,030H,00FH,004H,004H,004H,004H,044H,084H,07FH,000H,000H,000H
DB 000H,080H,040H,030H,00FH,004H,004H,004H,004H,044H,084H,07FH,000H,000H,000H,000H
DB 080H,040H,030H,00FH,004H,004H,004H,004H,044H,084H,07FH,000H,000H,000H,000H,080H
DB 040H,030H,00FH,004H,004H,004H,004H,044H,084H,07FH,000H,000H,000H,000H,080H,040H
DB 030H,00FH,004H,004H,004H,004H,044H,084H,07FH,000H,000H,000H,000H,000H,000H,000H
DB 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
end
答 1: 我也想啊我也有一个程序想让人帮忙汇编改C语言啊。 答 2: 没有硬件的资料怎样翻译呀】 答 3: 端口不是已经定义好了吗? 答 4: 求人不如求己我已经改完了,还得靠自己呀!
答 5: 这种苦力活当然得靠自己
CS1 bit p1.2
RESET bit P1.5
RS bit P1.0
E_RD bit P1.4
WR_RW bit P1.1
CR EQU 54H
CR_BACK EQU 53H
ORG 0000H
START:
CLR E_RD
CLR CS1
LCALL DELAY
SETB RESET
LCALL DELAY
LCALL WCOM
LCALL DELAY
LCALL WCOM
LCALL DELAY
LCALL WCOM
LCALL WCOM
; LCALL WCOM
LCALL WCOM
LCALL WCOM
LCALL WCOM
LCALL WCOM
LCALL WCOM
LCALL WCOM
LCALL WCOM
MAIN:
MOV DPTR,#SUCCESS
LCALL DISPLAY
;LCALL ICON
LCALL WAITKEY
MOV DPTR,#TAB4
LCALL DISPLAY
;LCALL ICON
LCALL WAITKEY
MOV R3,#00H
LCALL TEST
MOV R3,#06
LCALL TEST
MOV R3,#012
LCALL TEST
MOV R3,#012H
LCALL TEST
MOV R3,#018H
LCALL TEST
; MOV R3,#01EH
; LCALL TEST
MOV R3,#024H
LCALL TEST
MOV R3,#06H
; LCALL CR_INCREASE
LCALL TEST
MOV R3,#0CH
; LCALL CR_INCREASE
LCALL TEST
;LCALL CLEAR
;LCALL WAITKEY
; LCALL ICON
LJMP START
ICON:
LCALL CLEAR
MOV A,#0B8H ;page8
LCALL WCOM
LCALL WCOM
LCALL WCOM
MOV R0,#132
ICON1:
MOV A,#0ffH
LCALL WDATA
;LCALL ICONDISP
LCALL WAITKEY
LCALL WAIT
DJNZ R0,ICON1
RET
ICONDISP:
LCALL CLEAR
MOV A,#0B6H
LCALL WCOM
MOV A,#010H
LCALL WCOM
MOV A,#00H
LCALL WCOM
LCALL WDATA
LCALL WAIT
RET
CLEAR:
MOV R2,#0B0H ;page0
MOV A,R2
CLEAR2:
MOV A,R2
LCALL WCOM
MOV A,#010H ;
LCALL WCOM
LCALL WCOM
MOV R0,#128
CLEAR1:
MOV A,#00
LCALL WDATA
DJNZ R0,CLEAR1
INC R2
RET
CR_INCREASE:
MOV A,CR
ADD A,#13H
MOV CR,A
RET
CR_RECOVER:
MOV CR,#015H
RET
CONTRAST:
BEGIN:
KEY2:
LCALL WCOM
LCALL WCOM
SETB P3.1
MOV C,P3.1
MOV 44H,#015
DELAY_20MS:
LCALL DELAY
DJNZ 44H,DELAY_20MS
JC KEY1
INC CR
LCALL WCOM
LCALL WCOM
KEY1:
SETB P3.2
MOV C,P3.2
JC CR_END
DEC CR
LCALL WCOM
LCALL WCOM
CR_END:
LCALL DELAY
SETB P3.7
MOV C,P3.7
JNC NEXT
LJMP BEGIN
NEXT:
MOV 44H,#015
NEXT1: LCALL DELAY
DJNZ 44H,NEXT1
RET
TEST:
MOV R2,#0B0H
LCALL WCOM
LCALL WCOM
LCALL WCOM
MOV R0,#06H
TEST0:
MOV A,R3
MOVC A,@A+DPTR
LCALL WDATA
INC DPTR
DJNZ R0,TEST0
DJNZ R1,TEST1
INC R2
CJNE R2,#0B9H,TEST2
LCALL DELAY
LCALL WAITKEY
RET
DISPLAY:
MOV R2,#0B0H
DISPLAY0:
MOV A,R2
LCALL WCOM
DISPLAY1:
LCALL WCOM
LCALL WCOM
MOV R0,#128
DISPLAY2:
MOV A,#0
MOVC A,@A+DPTR
LCALL WDATA
INC DPTR
DJNZ R0,DISPLAY2
INC R2
LCALL CONTRAST
RET
EXCHANGE:PUSH B
CLR C
RLC A
MOV B.0,C
RLC A
MOV B.1,C
RLC A
MOV B.2,C
RLC A
MOV B.3,C
RLC A
MOV B.4,C
RLC A
MOV B.5,C
RLC A
MOV B.6,C
RLC A
MOV B.7,C
MOV A,B
POP B
RET
SMAP4: LCALL DELAY
DJNZ R5,SMAP4
SMAP3: MOV R4,#00H
MOV R1,#40H
SMAP1: MOV A,#40H
ORL A,R4
LCALL WCOM
LCALL DELAY
INC R4
MOV P3,#0FFH
MOV 67H,#08H
SMAP5: LCALL DELAY
DJNZ 67H,SMAP5
MOV C,P3.7
JNC SMAP2
LCALL DELAY
MOV C,P3.7
JNC SMAP2
DJNZ R1,SMAP1
LJMP SMAP3
SMAP2: LCALL DELAY
MOV A,#40H
LCALL WCOM
RET
;SELECT SUBPROGRAM
WAITKEY:SETB P3.7
MOV 43H,#80
WAITKEY1:
DJNZ 43H,WAITKEY1
STATUS: MOV C,P3.7
JC STATUS
RET
WAIT: MOV 42,#2FH
WAIT0: LCALL DELAY
DJNZ 42,WAIT0
RET
;DELAY SUBPROGRAM
DJNZ 40H,DELAY1
RET
WCOM:
CLR CS1
CLR RS
CLR WR_RW
LJMP TRANSMIT
WDATA:
CLR CS1
SETB RS
CLR WR_RW
; CLR WR_RW
TRANSMIT:
CLR E_RD
; NOP
;SETB E_RD
MOV P2,A
NOP
NOP
NOP
NOP
SETB E_RD
NOP
NOP
NOP
nop
CLR E_RD
; SETB CS1
RET
CHAR:
SUCCESS:
;-- 宽度x高度=128x64 --
;-- 宽度x高度=128x64 --
end
答 5: 这种苦力活当然得靠自己
共4条
