LCD1,ADC0,ADC3 我写的在LCD1~4行上显示ADC0~ADC3
问
'************************BASCOM-AVR试验程序 ***********************
'*********************ADC0~ADC3在LCD的1~4行显示*******************
'以下程序正在运行
$regfile = "m8def.dat"
$crystal = 4000000
Config Lcd = 20 * 4
Config Lcdmode = Port
Config Lcdpin = Pin , Db4 = Portd.6 , Db5 = Portd.5 , Db6 = Portb.7 , Db7 = Portb.6 , E = Portd.7 , Rs = Portb.0
'LCD的数据线采用4Bit且分配了portb和portd难为编译器啦!
Dim Ch0 As Word
Dim Ch1 As Word
Dim Ch2 As Word
Dim Ch3 As Word
Config Adc = Single , Prescaler = Auto , Reference = Internal
'单次转换,自动时钟,内部参考'当single改为free连续转换时LCD无显示有问题
Config Pinc.0 = Input
Config Pinc.1 = Input
Config Pinc.2 = Input
Config Pinc.3 = Input
Config Pind.4 = Output
Start Adc
Cls 'LCD清屏
Do
Ch0 = Getadc(0) '将ADC0的值赋给CH0
Ch0 = Ch0 * 25
Ch0 = Ch0 / 10 '加了个系数和电表量的有个对应
Ch1 = Getadc(1)
Ch1 = Ch1 * 25
Ch1 = Ch1 / 10
Ch2 = Getadc(2)
Ch2 = Ch2 * 25
Ch2 = Ch2 / 10
Ch3 = Getadc(3)
Ch3 = Ch3 * 25
Ch3 = Ch3 / 10
Cls
Locate 1 , 1 '定位第一行第一个字符
Lcd "CH0=" '显示CH=0字符串
Locate 1 , 5
Lcd Ch0 '显示CH0的值,我没有数制变换它自己就是10进制显示的
Locate 2 , 1
Lcd "CH1="
Locate 2 , 5
Lcd Ch1
Locate 3 , 1
Lcd "CH2="
Locate 3 , 5
Lcd Ch2
Locate 4 , 1
Lcd "CH3="
Locate 4 , 5
Lcd Ch3
Waitms 200 '不延时的时候LCD看不清
Set Portd.4 'PORTB.4上有个LED在闪
Waitms 200
Reset Portd.4
Loop
End 答 1: 显示格式最好加:FORMAT(S,“ ”)函数 答 2: 谢谢,先看了HELP再试 在8515的板上做了个mega8的适配插座。
'以下程序正在运行
$crystal = 4000000
Config Lcd = 20 * 4
Dim Ch0 As Word
Dim Ch1 As Word
Dim Ch2 As Word
Dim Ch3 As Word
Start Adc
Cls 'LCD清屏
Do
Ch0 = Ch0 * 25
Ch1 = Getadc(1)
Ch1 = Ch1 * 25
Ch1 = Ch1 / 10
Ch2 = Getadc(2)
Ch2 = Ch2 * 25
Ch2 = Ch2 / 10
Ch3 = Getadc(3)
Ch3 = Ch3 * 25
Ch3 = Ch3 / 10
Cls
Locate 1 , 5
Locate 2 , 1
Lcd "CH1="
Locate 2 , 5
Lcd Ch1
Locate 3 , 1
Lcd "CH2="
Locate 3 , 5
Lcd Ch2
Locate 4 , 1
Lcd "CH3="
Locate 4 , 5
Lcd Ch3
Waitms 200
Reset Portd.4
Loop
