问
#include <io8515.h>
#define uchar unsigned char
void main(void)
DDRA = 0x0;
答 1: 怎么不会过!我把您的程序复制到ICC中,编译通过。也能够生成所需的代码。
是否是扩展名错,应为“.C”。 答 2: 是不是头文件不对?// CodeVisionAVR C Compiler
// (C) 1998-2000 Pavel Haiduc, HP InfoTech S.R.L.
// I/O registers definitions for the AT90S8515
#ifndef _90S8515_INCLUDED_
#define _90S8515_INCLUDED_
#pragma used+
sfrb ACSR=8;
sfrb UBRR=9;
sfrb UCR=0xa;
sfrb USR=0xb;
sfrb UDR=0xc;
sfrb SPCR=0xd;
sfrb SPSR=0xe;
sfrb SPDR=0xf;
sfrb PIND=0x10;
sfrb DDRD=0x11;
sfrb PORTD=0x12;
sfrb PINC=0x13;
sfrb DDRC=0x14;
sfrb PORTC=0x15;
sfrb PINB=0x16;
sfrb DDRB=0x17;
sfrb PORTB=0x18;
sfrb PINA=0x19;
sfrb DDRA=0x1a;
sfrb PORTA=0x1b;
sfrb EECR=0x1c;
sfrb EEDR=0x1d;
sfrb EEARL=0x1e;
sfrb EEARH=0x1f;
sfrw EEAR=0x1e; // 16 bit access
sfrb WDTCR=0x21;
sfrb ICR1L=0x24;
sfrb ICR1H=0x25;
sfrw ICR1=0x24; // 16 bit access
sfrb OCR1BL=0x28;
sfrb OCR1BH=0x29;
sfrw OCR1B=0x28; // 16 bit access
sfrb OCR1AL=0x2a;
sfrb OCR1AH=0x2b;
sfrw OCR1A=0x2a; // 16 bit access
sfrb TCNT1L=0x2c;
sfrb TCNT1H=0x2d;
sfrw TCNT1=0x2c; // 16 bit access
sfrb TCCR1B=0x2e;
sfrb TCCR1A=0x2f;
sfrb TCNT0=0x32;
sfrb TCCR0=0x33;
sfrb MCUSR=0x34;
sfrb MCUCR=0x35;
sfrb TIFR=0x38;
sfrb TIMSK=0x39;
sfrb GIFR=0x3a;
sfrb GIMSK=0x3b;
sfrb SPL=0x3d;
sfrb SPH=0x3e;
sfrb SREG=0x3f;
#pragma used-
// Interrupt vectors definitions
#define EXT_INT0 2
#define EXT_INT1 3
#define TIM1_CAPT 4
#define TIM1_COMPA 5
#define TIM1_COMPB 6
#define TIM1_OVF 7
#define TIM0_OVF 8
#define SPI_STC 9
#define UART_RXC 10
#define UART_DRE 11
#define UART_TXC 12
#define ANA_COMP 13
#endif
答 3: 是ICCAVR 6.26版本编译应是路径设置不对!检查路径。
在6.26中,应改为io8515v.h
答 4: 编译应该能通过,但可能有警告。 答 5: ICC安装时目录不能有空格。如:program files是不行的。 答 6: 试试看将项目放在\**\**\bin目录下、头文件名称后加v试试看 答 7: :)(没有问题呀!
#include <io8515.h>
void main(void)
DDRA = 0x0;
#pragma used+
sfrb ACSR=8;
sfrb UBRR=9;
sfrb UCR=0xa;
sfrb USR=0xb;
sfrb UDR=0xc;
sfrb SPCR=0xd;
sfrb SPSR=0xe;
sfrb SPDR=0xf;
sfrb PIND=0x10;
sfrb DDRD=0x11;
sfrb PORTD=0x12;
sfrb PINC=0x13;
sfrb DDRC=0x14;
sfrb PORTC=0x15;
sfrb PINB=0x16;
sfrb DDRB=0x17;
sfrb PORTB=0x18;
sfrb PINA=0x19;
sfrb DDRA=0x1a;
sfrb PORTA=0x1b;
sfrb EECR=0x1c;
sfrb EEDR=0x1d;
sfrb EEARL=0x1e;
sfrb EEARH=0x1f;
sfrb WDTCR=0x21;
sfrb ICR1L=0x24;
sfrb ICR1H=0x25;
sfrb OCR1BL=0x28;
sfrb OCR1BH=0x29;
sfrb OCR1AL=0x2a;
sfrb OCR1AH=0x2b;
sfrb TCNT1L=0x2c;
sfrb TCNT1H=0x2d;
sfrb TCCR1B=0x2e;
sfrb TCCR1A=0x2f;
sfrb TCNT0=0x32;
sfrb TCCR0=0x33;
sfrb MCUSR=0x34;
sfrb MCUCR=0x35;
sfrb TIFR=0x38;
sfrb TIMSK=0x39;
sfrb GIFR=0x3a;
sfrb GIMSK=0x3b;
sfrb SPL=0x3d;
sfrb SPH=0x3e;
sfrb SREG=0x3f;
#pragma used-
#define EXT_INT0 2
#define EXT_INT1 3
#define TIM1_CAPT 4
#define TIM1_OVF 7
#define TIM0_OVF 8
#define SPI_STC 9
#define UART_RXC 10
#define UART_DRE 11
#define UART_TXC 12
#define ANA_COMP 13
#endif
在6.26中,应改为io8515v.h
| OrangePiZero2W系统被打赏¥33元 | |
