用的是FlashFXP
共4条
今天又试了,还不行
WinSock 2.0 -- OpenSSL 0.9.8a 11 Oct 2005
[R] 正在连接到 电子产品世界 -> IP=168.160.18.42 PORT=21
[R] 已连接到 电子产品世界
[R] 220 Serv-U FTP Server v6.3 for WinSock ready...
[R] USER eepw
[R] 331 User name okay, need password.
[R] PASS (hidden)
[R] 230 User logged in, proceed.
[R] SYST
[R] 215 UNIX Type: L8
[R] FEAT
[R] 211-Extension supported
[R] CLNT
[R] MDTM
[R] MDTM YYYYMMDDHHMMSS[+-TZ];filename
[R] SIZE
[R] SITE PSWD;EXEC;SET;INDEX;ZONE;CHMOD;MSG
[R] REST STREAM
[R] XCRC filename;start;end
[R] MODE Z
[R] MLST Type*;Size*;Create;Modify*;Win32.ea*;
[R] 211 End
[R] CLNT FlashFXP 3.4.0.1145
[R] 200 Noted.
[R] PWD
[R] 257 "/d:/ftp" is current directory.
[R] TYPE A
[R] 200 Type set to A.
[R] MODE Z
[R] 200 MODE Z ok.
[R] PASV
[R] 227 Entering Passive Mode (168,160,18,42,14,238)
[R] 正在打开数据连接 IP: 168.160.18.42 端口: 3822
[R] 数据 Socket 错误:连接已超时
[R] 列表错误
[R] PASV
[R] 227 Entering Passive Mode (168,160,18,42,14,242)
[R] 正在打开数据连接 IP: 168.160.18.42 端口: 3826
[R] 列表错误
[R] PASV 模式失败,正在尝试 PORT 模式。
[R] 侦听于端口: 2455,正在等候连接。
[R] PORT 192,168,1,19,9,151
[R] 200 PORT Command successful.
[R] LIST -al
[R] 150 Opening ASCII mode data connection for /bin/ls.
[R] 426 Data connection closed, transfer aborted.
[R] 列表错误
[R] 已连接到 电子产品世界
[R] USER eepw
[R] PASS (hidden)
[R] SYST
[R] FEAT
[R] CLNT
[R] MDTM
[R] SIZE
[R] REST STREAM
[R] MODE Z
[R] 211 End
[R] 200 Noted.
[R] PWD
[R] TYPE A
[R] MODE Z
[R] 200 MODE Z ok.
[R] PASV
[R] 列表错误
[R] PASV
[R] 列表错误
[R] LIST -al
[R] 列表错误
共4条
