电子产品世界 » 论坛首页 » 活动中心 » 下载专区 » [分享]C8051F020的液晶显示源码(C语言)
共6条 1/1 1 跳转至页
2007-03-22 22:38:52     打赏
当初学习的时候找的一点资料..
由一个头文件和两个C源文件组成..
由于太长,可能要分开发.....
关键词: 分享     C8051F020     液晶显示     源码     语言
2007-03-22 22:40:00     打赏
这是头文件...
#ifndef _C8051F020_
#define _C8051F020_
#define SYSCLK 11059200 // 系统时钟取自外部晶体
; Copyright (C) 2001 CYGNAL INTEGRATED PRODUCTS, INC.
; All rights reserved.
; FILE NAME : C8051F020.H
; TARGET MCUs : C8051F020, 'F021, 'F022, 'F023
; DESCRIPTION : Register/bit definitions for the C8051F02x product family.
; REVISION 1.0
/* BYTE Registers */
sfr P0 = 0x80; /* PORT 0 */
sfr SP = 0x81; /* STACK POINTER */
sfr DPL = 0x82; /* DATA POINTER - LOW BYTE */
sfr DPH = 0x83; /* DATA POINTER - HIGH BYTE */
sfr P4 = 0x84; /* PORT 4 */
sfr P5 = 0x85; /* PORT 5 */
sfr P6 = 0x86; /* PORT 6 */
sfr PCON = 0x87; /* POWER CONTROL */
sfr TCON = 0x88; /* TIMER CONTROL */
sfr TMOD = 0x89; /* TIMER MODE */
sfr TL0 = 0x8A; /* TIMER 0 - LOW BYTE */
sfr TL1 = 0x8B; /* TIMER 1 - LOW BYTE */
sfr TH0 = 0x8C; /* TIMER 0 - HIGH BYTE */
sfr TH1 = 0x8D; /* TIMER 1 - HIGH BYTE */
sfr CKCON = 0x8E; /* CLOCK CONTROL */
sfr PSCTL = 0x8F; /* PROGRAM STORE R/W CONTROL */
sfr P1 = 0x90; /* PORT 1 */
sfr TMR3CN = 0x91; /* TIMER 3 CONTROL */
sfr TMR3RLL = 0x92; /* TIMER 3 RELOAD REGISTER - LOW BYTE */
sfr TMR3RLH = 0x93; /* TIMER 3 RELOAD REGISTER - HIGH BYTE */
sfr TMR3L = 0x94; /* TIMER 3 - LOW BYTE */
sfr TMR3H = 0x95; /* TIMER 3 - HIGH BYTE */
sfr P7 = 0x96; /* PORT 7 */
sfr SCON0 = 0x98; /* SERIAL PORT 0 CONTROL */
sfr SBUF0 = 0x99; /* SERIAL PORT 0 BUFFER */
sfr SPI0CFG = 0x9A; /* SERIAL PERIPHERAL INTERFACE 0 CONFIGURATION */
sfr SPI0DAT = 0x9B; /* SERIAL PERIPHERAL INTERFACE 0 DATA */
sfr ADC1 = 0x9C; /* ADC 1 DATA */
sfr SPI0CKR = 0x9D; /* SERIAL PERIPHERAL INTERFACE 0 CLOCK RATE CONTROL */
sfr CPT0CN = 0x9E; /* COMPARATOR 0 CONTROL */
sfr CPT1CN = 0x9F; /* COMPARATOR 1 CONTROL */
sfr P2 = 0xA0; /* PORT 2 */
sfr EMI0TC = 0xA1; /* EMIF TIMING CONTROL */
sfr EMI0CF = 0xA3; /* EXTERNAL MEMORY INTERFACE (EMIF) CONFIGURATION */
sfr P0MDOUT = 0xA4; /* PORT 0 OUTPUT MODE CONFIGURATION */
sfr P1MDOUT = 0xA5; /* PORT 1 OUTPUT MODE CONFIGURATION */
sfr P2MDOUT = 0xA6; /* PORT 2 OUTPUT MODE CONFIGURATION */
sfr P3MDOUT = 0xA7; /* PORT 3 OUTPUT MODE CONFIGURATION */
sfr IE = 0xA8; /* INTERRUPT ENABLE */
sfr SADDR0 = 0xA9; /* SERIAL PORT 0 SLAVE ADDRESS */
sfr ADC1CN = 0xAA; /* ADC 1 CONTROL */
sfr ADC1CF = 0xAB; /* ADC 1 ANALOG MUX CONFIGURATION */
sfr AMX1SL = 0xAC; /* ADC 1 ANALOG MUX CHANNEL SELECT */
sfr P3IF = 0xAD; /* PORT 3 EXTERNAL INTERRUPT FLAGS */
sfr SADEN1 = 0xAE; /* SERIAL PORT 1 SLAVE ADDRESS MASK */
sfr EMI0CN = 0xAF; /* EXTERNAL MEMORY INTERFACE CONTROL */
sfr P3 = 0xB0; /* PORT 3 */
sfr OSCXCN = 0xB1; /* EXTERNAL OSCILLATOR CONTROL */
sfr OSCICN = 0xB2; /* INTERNAL OSCILLATOR CONTROL */
sfr P74OUT = 0xB5; /* PORTS 4 - 7 OUTPUT MODE */
sfr FLSCL = 0xB6; /* FLASH MEMORY TIMING PRESCALER */
sfr FLACL = 0xB7; /* FLASH ACESS LIMIT */
sfr IP = 0xB8; /* INTERRUPT PRIORITY */
sfr SADEN0 = 0xB9; /* SERIAL PORT 0 SLAVE ADDRESS MASK */
sfr AMX0CF = 0xBA; /* ADC 0 MUX CONFIGURATION */
sfr AMX0SL = 0xBB; /* ADC 0 MUX CHANNEL SELECTION */
sfr ADC0CF = 0xBC; /* ADC 0 CONFIGURATION */
sfr P1MDIN = 0xBD; /* PORT 1 INPUT MODE */
sfr ADC0L = 0xBE; /* ADC 0 DATA - LOW BYTE */
sfr ADC0H = 0xBF; /* ADC 0 DATA - HIGH BYTE */
sfr SMB0CN = 0xC0; /* SMBUS 0 CONTROL */
sfr SMB0STA = 0xC1; /* SMBUS 0 STATUS */
sfr SMB0DAT = 0xC2; /* SMBUS 0 DATA */
sfr SMB0ADR = 0xC3; /* SMBUS 0 SLAVE ADDRESS */
sfr ADC0GTL = 0xC4; /* ADC 0 GREATER-THAN REGISTER - LOW BYTE */
sfr ADC0GTH = 0xC5; /* ADC 0 GREATER-THAN REGISTER - HIGH BYTE */
sfr ADC0LTL = 0xC6; /* ADC 0 LESS-THAN REGISTER - LOW BYTE */
sfr ADC0LTH = 0xC7; /* ADC 0 LESS-THAN REGISTER - HIGH BYTE */
sfr T2CON = 0xC8; /* TIMER 2 CONTROL */
sfr T4CON = 0xC9; /* TIMER 4 CONTROL */
sfr RCAP2L = 0xCA; /* TIMER 2 CAPTURE REGISTER - LOW BYTE */
sfr RCAP2H = 0xCB; /* TIMER 2 CAPTURE REGISTER - HIGH BYTE */
sfr TL2 = 0xCC; /* TIMER 2 - LOW BYTE */
sfr TH2 = 0xCD; /* TIMER 2 - HIGH BYTE */
sfr SMB0CR = 0xCF; /* SMBUS 0 CLOCK RATE */
sfr PSW = 0xD0; /* PROGRAM STATUS WORD */
sfr REF0CN = 0xD1; /* VOLTAGE REFERENCE 0 CONTROL */
sfr DAC0L = 0xD2; /* DAC 0 REGISTER - LOW BYTE */
sfr DAC0H = 0xD3; /* DAC 0 REGISTER - HIGH BYTE */
sfr DAC0CN = 0xD4; /* DAC 0 CONTROL */
sfr DAC1L = 0xD5; /* DAC 1 REGISTER - LOW BYTE */
sfr DAC1H = 0xD6; /* DAC 1 REGISTER - HIGH BYTE */
sfr DAC1CN = 0xD7; /* DAC 1 CONTROL */
sfr PCA0CN = 0xD8; /* PCA 0 COUNTER CONTROL */
sfr PCA0MD = 0xD9; /* PCA 0 COUNTER MODE */
sfr PCA0CPM0 = 0xDA; /* CONTROL REGISTER FOR PCA 0 MODULE 0 */
sfr PCA0CPM1 = 0xDB; /* CONTROL REGISTER FOR PCA 0 MODULE 1 */
sfr PCA0CPM2 = 0xDC; /* CONTROL REGISTER FOR PCA 0 MODULE 2 */
sfr PCA0CPM3 = 0xDD; /* CONTROL REGISTER FOR PCA 0 MODULE 3 */
sfr PCA0CPM4 = 0xDE; /* CONTROL REGISTER FOR PCA 0 MODULE 4 */
sfr ACC = 0xE0; /* ACCUMULATOR */
sfr XBR0 = 0xE1; /* DIGITAL CROSSBAR CONFIGURATION REGISTER 0 */
sfr XBR1 = 0xE2; /* DIGITAL CROSSBAR CONFIGURATION REGISTER 1 */
sfr XBR2 = 0xE3; /* DIGITAL CROSSBAR CONFIGURATION REGISTER 2 */
sfr RCAP4L = 0xE4; /* TIMER 4 CAPTURE REGISTER - LOW BYTE */
sfr RCAP4H = 0xE5; /* TIMER 4 CAPTURE REGISTER - HIGH BYTE */
sfr EIE1 = 0xE6; /* EXTERNAL INTERRUPT ENABLE 1 */
sfr EIE2 = 0xE7; /* EXTERNAL INTERRUPT ENABLE 2 */
sfr ADC0CN = 0xE8; /* ADC 0 CONTROL */
sfr PCA0L = 0xE9; /* PCA 0 TIMER - LOW BYTE */
sfr PCA0CPL0 = 0xEA; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 0 - LOW BYTE */
sfr PCA0CPL1 = 0xEB; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 1 - LOW BYTE */
sfr PCA0CPL2 = 0xEC; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 2 - LOW BYTE */
sfr PCA0CPL3 = 0xED; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 3 - LOW BYTE */
sfr PCA0CPL4 = 0xEE; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 4 - LOW BYTE */
sfr RSTSRC = 0xEF; /* RESET SOURCE */
sfr B = 0xF0; /* B REGISTER */
sfr SCON1 = 0xF1; /* SERIAL PORT 1 CONTROL */
sfr SBUF1 = 0xF2; /* SERAIL PORT 1 DATA */
sfr SADDR1 = 0xF3; /* SERAIL PORT 1 */
sfr TL4 = 0xF4; /* TIMER 4 DATA - LOW BYTE */
sfr TH4 = 0xF5; /* TIMER 4 DATA - HIGH BYTE */
sfr EIP1 = 0xF6; /* EXTERNAL INTERRUPT PRIORITY REGISTER 1 */
sfr EIP2 = 0xF7; /* EXTERNAL INTERRUPT PRIORITY REGISTER 2 */
sfr SPI0CN = 0xF8; /* SERIAL PERIPHERAL INTERFACE 0 CONTROL */
sfr PCA0H = 0xF9; /* PCA 0 TIMER - HIGH BYTE */
sfr PCA0CPH0 = 0xFA; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 0 - HIGH BYTE */
sfr PCA0CPH1 = 0xFB; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 1 - HIGH BYTE */
sfr PCA0CPH2 = 0xFC; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 2 - HIGH BYTE */
sfr PCA0CPH3 = 0xFD; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 3 - HIGH BYTE */
sfr PCA0CPH4 = 0xFE; /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 4 - HIGH BYTE */
sfr WDTCN = 0xFF; /* WATCHDOG TIMER CONTROL */
/* BIT Registers */
/* TCON 0x88 */
sbit TF1 = TCON ^ 7; /* TIMER 1 OVERFLOW FLAG */
sbit TR1 = TCON ^ 6; /* TIMER 1 ON/OFF CONTROL */
sbit TF0 = TCON ^ 5; /* TIMER 0 OVERFLOW FLAG */
sbit TR0 = TCON ^ 4; /* TIMER 0 ON/OFF CONTROL */
sbit IE1 = TCON ^ 3; /* EXT. INTERRUPT 1 EDGE FLAG */
sbit IT1 = TCON ^ 2; /* EXT. INTERRUPT 1 TYPE */
sbit IE0 = TCON ^ 1; /* EXT. INTERRUPT 0 EDGE FLAG */
sbit IT0 = TCON ^ 0; /* EXT. INTERRUPT 0 TYPE */
/* SCON0 0x98 */
sbit SM00 = SCON0 ^ 7; /* SERIAL MODE CONTROL BIT 0 */
sbit SM10 = SCON0 ^ 6; /* SERIAL MODE CONTROL BIT 1 */
sbit SM20 = SCON0 ^ 5; /* MULTIPROCESSOR COMMUNICATION ENABLE */
sbit REN0 = SCON0 ^ 4; /* RECEIVE ENABLE */
sbit TB80 = SCON0 ^ 3; /* TRANSMIT BIT 8 */
sbit RB80 = SCON0 ^ 2; /* RECEIVE BIT 8 */
sbit TI0 = SCON0 ^ 1; /* TRANSMIT INTERRUPT FLAG */
sbit RI0 = SCON0 ^ 0; /* RECEIVE INTERRUPT FLAG */
/* IE 0xA8 */
sbit EA = IE ^ 7; /* GLOBAL INTERRUPT ENABLE */
sbit ET2 = IE ^ 5; /* TIMER 2 INTERRUPT ENABLE */
sbit ES0 = IE ^ 4; /* SERIAL PORT INTERRUPT ENABLE */
sbit ET1 = IE ^ 3; /* TIMER 1 INTERRUPT ENABLE */
sbit EX1 = IE ^ 2; /* EXTERNAL INTERRUPT 1 ENABLE */
sbit ET0 = IE ^ 1; /* TIMER 0 INTERRUPT ENABLE */
sbit EX0 = IE ^ 0; /* EXTERNAL INTERRUPT 0 ENABLE */
/* IP 0xB8 */
sbit PT2 = IP ^ 5; /* TIMER 2 PRIORITY */
sbit PS = IP ^ 4; /* SERIAL PORT PRIORITY */
sbit PT1 = IP ^ 3; /* TIMER 1 PRIORITY */
sbit PX1 = IP ^ 2; /* EXTERNAL INTERRUPT 1 PRIORITY */
sbit PT0 = IP ^ 1; /* TIMER 0 PRIORITY */
sbit PX0 = IP ^ 0; /* EXTERNAL INTERRUPT 0 PRIORITY */
/* SMB0CN 0xC0 */
sbit BUSY = SMB0CN ^ 7; /* SMBUS 0 BUSY */
sbit ENSMB = SMB0CN ^ 6; /* SMBUS 0 ENABLE */
sbit STA = SMB0CN ^ 5; /* SMBUS 0 START FLAG */
sbit STO = SMB0CN ^ 4; /* SMBUS 0 STOP FLAG */
sbit SI = SMB0CN ^ 3; /* SMBUS 0 INTERRUPT PENDING FLAG */
sbit AA = SMB0CN ^ 2; /* SMBUS 0 ASSERT/ACKNOWLEDGE FLAG */
sbit SMBFTE = SMB0CN ^ 1; /* SMBUS 0 FREE TIMER ENABLE */
sbit SMBTOE = SMB0CN ^ 0; /* SMBUS 0 TIMEOUT ENABLE */
/* T2CON 0xC8 */
sbit TF2 = T2CON ^ 7; /* TIMER 2 OVERFLOW FLAG */
sbit EXF2 = T2CON ^ 6; /* EXTERNAL FLAG */
sbit RCLK = T2CON ^ 5; /* RECEIVE CLOCK FLAG */
sbit TCLK = T2CON ^ 4; /* TRANSMIT CLOCK FLAG */
sbit EXEN2 = T2CON ^ 3; /* TIMER 2 EXTERNAL ENABLE FLAG */
sbit TR2 = T2CON ^ 2; /* TIMER 2 ON/OFF CONTROL */
sbit CT2 = T2CON ^ 1; /* TIMER OR COUNTER SELECT */
sbit CPRL2 = T2CON ^ 0; /* CAPTURE OR RELOAD SELECT */
/* PSW */
sbit CY = PSW ^ 7; /* CARRY FLAG */
sbit AC = PSW ^ 6; /* AUXILIARY CARRY FLAG */
sbit F0 = PSW ^ 5; /* USER FLAG 0 */
sbit RS1 = PSW ^ 4; /* REGISTER BANK SELECT 1 */
sbit RS0 = PSW ^ 3; /* REGISTER BANK SELECT 0 */
sbit OV = PSW ^ 2; /* OVERFLOW FLAG */
sbit F1 = PSW ^ 1; /* USER FLAG 1 */
sbit P = PSW ^ 0; /* ACCUMULATOR PARITY FLAG */
/* PCA0CN D8H */
sbit CF = PCA0CN ^ 7; /* PCA 0 COUNTER OVERFLOW FLAG */
sbit CR = PCA0CN ^ 6; /* PCA 0 COUNTER RUN CONTROL BIT */
sbit CCF4 = PCA0CN ^ 4; /* PCA 0 MODULE 4 INTERRUPT FLAG */
sbit CCF3 = PCA0CN ^ 3; /* PCA 0 MODULE 3 INTERRUPT FLAG */
sbit CCF2 = PCA0CN ^ 2; /* PCA 0 MODULE 2 INTERRUPT FLAG */
sbit CCF1 = PCA0CN ^ 1; /* PCA 0 MODULE 1 INTERRUPT FLAG */
sbit CCF0 = PCA0CN ^ 0; /* PCA 0 MODULE 0 INTERRUPT FLAG */
/* ADC0CN E8H */
sbit AD0EN = ADC0CN ^ 7; /* ADC 0 ENABLE */
sbit AD0TM = ADC0CN ^ 6; /* ADC 0 TRACK MODE */
sbit AD0INT = ADC0CN ^ 5; /* ADC 0 CONVERISION COMPLETE INTERRUPT FLAG */
sbit AD0BUSY = ADC0CN ^ 4; /* ADC 0 BUSY FLAG */
sbit AD0CM1 = ADC0CN ^ 3; /* ADC 0 START OF CONVERSION MODE BIT 1 */
sbit AD0CM0 = ADC0CN ^ 2; /* ADC 0 START OF CONVERSION MODE BIT 0 */
sbit AD0WINT = ADC0CN ^ 1; /* ADC 0 WINDOW COMPARE INTERRUPT FLAG */
sbit AD0LJST = ADC0CN ^ 0; /* ADC 0 RIGHT JUSTIFY DATA BIT */
/* SPI0CN F8H */
sbit SPIF = SPI0CN ^ 7; /* SPI 0 INTERRUPT FLAG */
sbit WCOL = SPI0CN ^ 6; /* SPI 0 WRITE COLLISION FLAG */
sbit MODF = SPI0CN ^ 5; /* SPI 0 MODE FAULT FLAG */
sbit RXOVRN = SPI0CN ^ 4; /* SPI 0 RX OVERRUN FLAG */
sbit TXBSY = SPI0CN ^ 3; /* SPI 0 TX BUSY FLAG */
sbit SLVSEL = SPI0CN ^ 2; /* SPI 0 SLAVE SELECT */
sbit MSTEN = SPI0CN ^ 1; /* SPI 0 MASTER ENABLE */
sbit SPIEN = SPI0CN ^ 0; /* SPI 0 SPI ENABLE */
sbit P10 = P1^0;
sbit P11 = P1^1;
sbit P12 = P1^2;
sbit P13 = P1^3;
sbit P14 = P1^4;
sbit P15 = P1^5;
sbit P16 = P1^6;
sbit P17 = P1^7;
sbit P20 = P2^0;
sbit P21 = P2^1;
sbit P22 = P2^2;
sbit P23 = P2^3;
sbit P24 = P2^4;
sbit P25 = P2^5;
sbit P26 = P2^6;
sbit P27 = P2^7;
sbit P30 = P3^0;
sbit P31 = P3^1;
sbit P32 = P3^2;
sbit P33 = P3^3;
sbit P34 = P3^4;
sbit P35 = P3^5;
sbit P36 = P3^6;
sbit P37 = P3^7;
#endif
2007-03-22 22:41:00     打赏
下面的是控制液晶的子函数
#include "c8051F020.h"
#include <intrins.h>
液晶点阵显示试验 -128*64,控制器KS0108
试验准备:将拨码开关S1和S2置于ON位置.
运行此程序,LCD将交替显示"换代创新后的51-高速SOC美国CYGNAL 8051F"
"新华龙电子-单片机推广应用急先锋!","汉字".
#define LCD_DATA P2
#define LCD_RS P30
#define LCD_RW P31
#define LCD_E P32
#define LCD_CS1 P33
#define LCD_CS2 P34
#define LCD_RST P35
void Delay1ms(unsigned char);
/*-- 宽度x高度=128x64 --*/
char code screen[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0xC0,0xC0,0x40,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x70,0xF0,0xE1,0x43,0x03,0xC3,0xFA,
0xF8,0x18,0x88,0xE8,0xFC,0x3F,0x0F,0x09,0x08,0xE8,0xF8,0x78,0x08,0x00,0x00,0x00,
0xE0,0xFC,0x7F,0xCF,0xE1,0xF9,0x3F,0x0F,0x83,0xF1,0xFE,0xBF,0x87,0x81,0x81,0x81,
0xC1,0xF9,0xFF,0x1F,0x07,0x00,0x00,0xC0,0xC0,0xC6,0xFE,0xFE,0xFE,0xC6,0xE7,0xFF,
0xFF,0xCE,0xC6,0xE6,0xFC,0x7F,0x4F,0xC1,0xC1,0xC1,0x41,0x41,0x41,0x01,0x00,0x20,
0x60,0x70,0x38,0xFC,0xFE,0x3F,0x2F,0x61,0x60,0xF0,0xF8,0xFF,0x1F,0x0B,0x0C,0x0C,
0x86,0xC7,0xC3,0x03,0x00,0x00,0x00,0x00,0x30,0x30,0x30,0x30,0x30,0x30,0xF0,0xF0,
0xFC,0xBF,0xF7,0xF1,0x30,0x30,0x3B,0x3F,0x37,0x36,0x30,0x30,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xE0,0xF0,0x78,0x3C,0x0C,0x80,0xC0,0xE0,0x70,
0x38,0xDE,0xFF,0xFF,0x1F,0x03,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0xC0,0xF8,0xFF,
0x7F,0x63,0x60,0x30,0x3F,0x1F,0xE6,0xFC,0xFF,0xCF,0xC1,0xC1,0xC1,0xC1,0xF1,0xFF,
0x3F,0x07,0x00,0x00,0x80,0xC0,0xCC,0x7C,0x7C,0xEC,0xFC,0xFF,0x7F,0xFF,0xFC,0x8C,
0xEC,0xF8,0x3F,0x0F,0x83,0xF0,0xFC,0x3F,0x07,0x00,0x00,0x00,0x00,0x20,0x20,0x20,
0x20,0x24,0x27,0x27,0x23,0xA0,0xF0,0xFC,0x3C,0x27,0x23,0x23,0x23,0x23,0x23,0x23,
0x23,0x23,0x01,0x00,0x00,0x00,0x80,0x80,0xC0,0xE0,0x70,0x38,0x1E,0x8F,0x87,0xF1,
0xFE,0x7F,0x77,0x38,0x1C,0x0E,0x87,0x83,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x01,0x00,0x04,0x06,0x07,0x03,0x01,0x00,0x00,
0x00,0x03,0x03,0x03,0x02,0x02,0x03,0x03,0x01,0x00,0x00,0x00,0x06,0x07,0x07,0x00,
0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x01,
0x00,0x00,0x00,0x00,0x01,0x01,0x06,0x06,0x06,0x07,0x03,0x00,0x00,0x06,0x07,0x03,
0x01,0x00,0x00,0x04,0x07,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x06,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x02,0x06,0x07,0x03,0x03,0x01,0x00,0x02,0x03,0x03,0x03,0x07,0x07,
0x07,0x06,0x06,0x06,0x06,0x06,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x80,0xC0,0x40,0x40,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0x80,
0x00,0x00,0x00,0xC0,0xC0,0xC0,0x40,0x00,0x00,0x00,0x80,0x80,0xC0,0x40,0x40,0xC0,
0xC0,0x80,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF8,0xFC,0x3F,
0x07,0x01,0x00,0x00,0x80,0x8C,0x8F,0x0F,0x07,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,
0x3C,0x1E,0x0F,0x03,0x01,0x00,0xC0,0xF8,0xFE,0x3F,0x07,0x21,0x20,0xE0,0xE0,0xE7,
0x27,0x07,0x00,0xC0,0xF8,0xFF,0x3F,0xFF,0xFF,0xFF,0xC0,0xF8,0xFF,0x3F,0x07,0x00,
0x00,0xC0,0xF0,0xF8,0xBE,0x8F,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0xC0,0xF8,0xFF,
0x3F,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,0x1F,0x10,
0x10,0x18,0x1C,0x0F,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x10,0x1E,0x1F,0x0F,0x01,
0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,0x1F,0x10,0x18,0x1C,0x1F,0x1F,0x0F,0x01,
0x00,0x10,0x1E,0x1F,0x0F,0x01,0x00,0x03,0x1F,0x1F,0x1F,0x0F,0x01,0x10,0x18,0x1E,
0x0F,0x07,0x01,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x00,0x00,0x10,0x1E,0x1F,0x1F,0x11,
0x10,0x10,0x10,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
char code screen1[]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x5F,0x3F,0x7F,0x7F,0xFF,0x3F,0x7F,
0x7F,0xBF,0x9F,0xBF,0xFF,0xFF,0xFF,0xFF,0x7F,0x9F,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,
0x7F,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xDF,0xBF,0x3F,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,
0xFF,0xFF,0xFF,0xFF,0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0x3F,0x9F,0xBF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xDB,0x5A,0xD9,0x03,0x59,0xDA,0xFF,0x00,0xFB,
0xFB,0x03,0xF9,0xFB,0xFF,0x7B,0x7D,0x7E,0x40,0x7F,0x7B,0x1B,0x70,0x6D,0x6E,0x6E,
0x6F,0x6F,0x63,0xFF,0xFD,0xFD,0xFD,0x7D,0x9D,0xE0,0xFD,0x7D,0x01,0xDD,0xED,0xF5,
0xFC,0x7D,0xFF,0xFF,0xFF,0x00,0xB6,0xB6,0xB6,0x00,0xB6,0xB6,0xB6,0xB6,0x80,0xFE,
0xFF,0xFF,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0x01,0xF5,0xF6,0xF7,0xF7,0xF3,0xF7,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xED,0xEE,0xED,0xEB,0xEC,0xEF,0xEA,0xED,0xEE,0xEF,
0xEF,0xE8,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xE8,0xEF,0xEF,0xEF,0xEF,
0xEF,0xEF,0xEF,0xEF,0xEB,0xED,0xEE,0xEF,0xEF,0xEE,0xEE,0xEF,0xEC,0xEB,0xEB,0xEB,
0xEB,0xE8,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEC,0xEB,0xEB,0xEB,0xEB,0xEB,0xEB,
0xE8,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xED,0xEB,0xEC,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,
0xEF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x07,0xD6,0xD5,0xD7,0x07,0xD7,0xD5,0xD6,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x01,0x6F,0x6F,0x6F,0x6F,0x60,0x6F,0xEF,0xEF,0xE7,0xEF,0xFF,0xEF,0xEF,0x2F,0x00,
0xAF,0x6F,0xFF,0x01,0xFD,0xFD,0x00,0xFD,0xFF,0xFF,0xFF,0xF7,0xF7,0x77,0x00,0xB7,
0xDF,0x07,0xB0,0xB7,0x06,0xB1,0xB7,0xB7,0xB7,0xFF,0xFF,0xFF,0x03,0xFB,0xFB,0xFB,
0xFA,0xF9,0xFB,0xFB,0xFB,0xFB,0xF9,0xFB,0xFF,0xFF,0xFF,0x03,0xFB,0xBB,0x7B,0xEA,
0xD9,0x3B,0xFB,0xFB,0x7B,0x99,0xFB,0xFF,0xFF,0xFF,0x01,0xED,0xED,0xED,0xED,0x01,
0xED,0xED,0xED,0x00,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xFB,
0xFA,0xFA,0xFA,0xFA,0xC0,0xFA,0xFA,0xFA,0xFA,0xFB,0xFB,0xFF,0xFF,0xDF,0xEF,0xF7,
0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFE,0xFF,0xC0,
0xDF,0xEF,0xF7,0xF8,0xFF,0xFF,0xE0,0xDF,0xDF,0xC3,0xFF,0xFE,0xEE,0xDF,0xE0,0xFF,
0xFF,0xC0,0xED,0xED,0xE0,0xED,0xED,0xED,0xED,0xFF,0xDF,0xE7,0xF8,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xE7,0xF8,0xEF,0xEF,0xEE,0xE9,
0xEF,0xEE,0xE7,0xE9,0xEE,0xE7,0xEF,0xFF,0xDF,0xE7,0xF8,0xFE,0xFE,0xFE,0xFE,0xC0,
0xFE,0xEE,0xDE,0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,
0xEF,0x57,0x5B,0x59,0x5B,0x5B,0x4B,0x53,0x5F,0x0F,0xDF,0xFF,0xFF,0xFF,0xBF,0xDF,
0xE3,0xEF,0xEF,0xEF,0x01,0xEF,0xEF,0xE7,0xEF,0x7F,0xFF,0xFF,0xBF,0x8F,0x31,0xB7,
0xB7,0x77,0x6F,0xB7,0xA9,0x5B,0xAB,0xB3,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,
0xE5,0xFD,0xC5,0xBD,0xB9,0xA5,0xBD,0xBD,0x8D,0xFC,0xF7,0xCF,0xFF,0xBE,0xBE,0xDE,
0xEE,0xF6,0xF8,0xFE,0xFE,0xC0,0xBE,0xBE,0xBE,0xBE,0x8E,0xFF,0xFD,0xFD,0xC0,0xED,
0xF5,0xED,0xEA,0xEA,0xEA,0x80,0xEA,0xEA,0xEB,0xEF,0xFF,0xFF,0xFF,0xFF,0xCC,0xCF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCC,0xCF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCC,0xCF,
char code screen2[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x10,0xFE,0x90,0xA0,0xD0,0x4E,0x48,
0xE8,0x58,0x40,0xC0,0x00,0x00,0x80,0x40,0x20,0xF8,0x06,0x40,0x40,0x40,0xFE,0x20,
0x20,0x24,0x38,0x20,0x00,0x40,0x20,0xD0,0x48,0x46,0x44,0xC8,0x10,0x00,0xF0,0x00,
0x00,0xFE,0x00,0x00,0x40,0x48,0x58,0x6A,0xCC,0x68,0x58,0x00,0xFC,0x48,0x48,0xC4,
0x66,0x44,0x00,0x00,0x00,0xF8,0x28,0x28,0x28,0x28,0x28,0x24,0x24,0x24,0xA6,0x24,
0x00,0x00,0x00,0xF0,0x18,0x16,0x10,0xF0,0x40,0x20,0x98,0x16,0x10,0x10,0xF8,0x10,
0x00,0x00,0xF0,0x10,0x90,0x90,0x90,0x10,0x00,0x00,0x20,0x20,0xF0,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x22,0x41,0x3F,0x40,0x44,0x27,0x14,0x0C,
0x07,0x1C,0x24,0x47,0x44,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x03,0x0C,
0x10,0x20,0x40,0x78,0x00,0x00,0x00,0x3F,0x40,0x44,0x44,0x43,0x70,0x00,0x07,0x20,
0x40,0x3F,0x00,0x00,0x20,0x12,0x2A,0x42,0x3F,0x0A,0x52,0x20,0x1F,0x00,0x00,0x7F,
0x00,0x00,0x00,0x40,0x30,0x0F,0x00,0x00,0x7F,0x21,0x21,0x21,0x21,0x21,0x7F,0x01,
0x00,0x00,0x00,0x7F,0x21,0x21,0x21,0x7F,0x00,0x00,0x00,0x23,0x40,0x20,0x1F,0x00,
0x00,0x00,0x19,0x21,0x20,0x20,0x20,0x1F,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,
0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x82,0x82,0xBA,0xAA,0xAA,0xAB,0xAA,
0xAA,0xBA,0x82,0x82,0x02,0x00,0x20,0x21,0xE6,0x00,0x04,0x74,0x54,0x54,0xFF,0xD4,
0x54,0x74,0x06,0x04,0x00,0x00,0x70,0x88,0x88,0x08,0x08,0x38,0x00,0xE0,0x10,0x08,
0x08,0x08,0x10,0xE0,0x00,0xE0,0x10,0x08,0x08,0x08,0x08,0x38,0x00,0x80,0x84,0x94,
0x94,0x95,0x96,0xFC,0x94,0x96,0x95,0x94,0xC4,0x80,0x00,0x00,0x00,0xFE,0x02,0x0A,
0x4A,0x4A,0xFA,0x4A,0xCA,0x4A,0x0A,0x02,0xFF,0x02,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x0E,0x0A,0x0A,0x0A,
0x0E,0x00,0x20,0x3F,0x00,0x00,0x10,0x08,0x07,0x08,0x10,0x24,0x22,0x21,0x2F,0x20,
0x21,0x22,0x24,0x20,0x00,0x00,0x1C,0x10,0x10,0x11,0x11,0x0E,0x00,0x07,0x08,0x10,
0x10,0x10,0x08,0x07,0x00,0x07,0x08,0x10,0x10,0x10,0x08,0x04,0x00,0x20,0x22,0x12,
0x12,0x0A,0x06,0x03,0x06,0x0A,0x12,0x12,0x22,0x20,0x00,0x00,0x00,0x3F,0x10,0x14,
0x14,0x14,0x17,0x14,0x14,0x15,0x14,0x14,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,
0x08,0x04,0x04,0x04,0x04,0x1C,0x00,0x20,0x60,0xA0,0x00,0x00,0xA0,0x60,0x20,0x00,
0xC0,0x20,0x20,0x20,0xE0,0x20,0x00,0x20,0xE0,0x40,0x20,0x20,0x20,0xC0,0x00,0x00,
0x40,0x20,0xA0,0xA0,0xC0,0x00,0x00,0x00,0x04,0x04,0xFC,0x00,0x00,0x00,0x00,0x00,
0x38,0xC4,0x44,0x44,0xC4,0x38,0x00,0x00,0xF0,0x08,0x04,0x04,0x08,0xF0,0x00,0x00,
0x7C,0x44,0x24,0x24,0x24,0xC4,0x00,0x00,0x08,0x08,0xFC,0x00,0x00,0x00,0x00,0x04,
0xFC,0x44,0x44,0xF4,0x04,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
0x04,0x08,0x08,0x08,0x04,0x02,0x00,0x20,0x20,0x23,0x1C,0x06,0x01,0x00,0x00,0x00,
0x1A,0x25,0x25,0x25,0x24,0x18,0x00,0x08,0x0F,0x08,0x00,0x00,0x08,0x0F,0x08,0x00,
0x06,0x09,0x08,0x08,0x0F,0x08,0x00,0x00,0x08,0x08,0x0F,0x08,0x08,0x00,0x00,0x00,
0x07,0x08,0x08,0x08,0x08,0x07,0x00,0x00,0x03,0x04,0x08,0x08,0x04,0x03,0x00,0x00,
0x06,0x08,0x08,0x08,0x08,0x07,0x00,0x00,0x08,0x08,0x0F,0x08,0x08,0x00,0x00,0x08,
0x0F,0x08,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
#define SELECTCS 0
void LCD_WaitReady1(void) //判断LCD控制芯片KS0108是否忙
LCD_DATA=0xff;
_nop_();
LCD_CS2=SELECTCS;
LCD_RW=1;
LCD_RS=0;
LCD_E=1;
while (LCD_DATA&0x80);
LCD_CS2=!SELECTCS;
void LCD_WaitReady2(void) //判断LCD控制芯片KS0108是否忙
LCD_DATA=0xff;
_nop_();
LCD_CS1=SELECTCS;
LCD_RW=1;
LCD_RS=0;
LCD_E=1;
LCD_CS1=!SELECTCS;
void LCD_WriteCommand1(char ch) //向LCD控制芯片KS0108发送控制命令
LCD_WaitReady1();
LCD_CS2=SELECTCS;
LCD_RW=0;
LCD_RS=0;
LCD_DATA=ch;
LCD_E=1;
LCD_E=0;
LCD_CS2=!SELECTCS;
void LCD_WriteCommand2(char ch) //向LCD控制芯片KS0108发送控制命令
LCD_WaitReady2();
LCD_CS1=SELECTCS;
LCD_RW=0;
LCD_RS=0;
LCD_DATA=ch;
LCD_E=1;
LCD_E=0;
LCD_CS1=!SELECTCS;
void LCD_WriteData1(char ch) //向LCD控制芯片KS0108发送数据命令
LCD_WaitReady1();
LCD_CS2=SELECTCS;
LCD_RW=0;
LCD_RS=1;
LCD_DATA=ch;
LCD_E=1;
LCD_E=0;
LCD_CS2=!SELECTCS;
void LCD_WriteData2(char ch) //向LCD控制芯片KS0108发送数据命令
LCD_WaitReady2();
LCD_CS1=SELECTCS;
LCD_RW=0;
LCD_RS=1;
LCD_DATA=ch;
LCD_E=1;
LCD_E=0;
LCD_CS1=!SELECTCS;
/*-- 文字: 汉 --*/
char code Han[]=
0x00,0x10,0x61,0x06,0xC0,0x30,0x02,0x3E,0xC2,0x02,0x82,0x62,0x1F,0x02,0x00,0x00,
0x00,0x02,0x02,0x3F,0x20,0x20,0x10,0x08,0x05,0x02,0x05,0x08,0x10,0x30,0x10,0x00,
/*-- 文字: 字 --*/
char code Zi[]=
0x00,0x00,0x10,0x0C,0x14,0x14,0x14,0x15,0xD6,0x54,0x34,0x14,0x14,0x8C,0x00,0x00,
0x00,0x01,0x01,0x01,0x01,0x01,0x11,0x21,0x1F,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
void LCD_WriteHZ(char x,char y,char *Dot) //显示16*16点阵汉字
char i;
for (i=0;i<32;i++)
if ((x+i%16)<64)
LCD_WriteCommand1(0xB8+y+i/16);
LCD_WriteCommand1(0x40+x+i%16);
LCD_WriteData1(Dot[i]);
else
LCD_WriteCommand2(0xB8+y+i/16);
LCD_WriteCommand2(0x40+x-64+i%16);
LCD_WriteData2(Dot[i]);
void InitLCD(void) //初始化LCD
char i,j;
LCD_RST=0;
Delay1ms(1);
LCD_RST=1;
LCD_WriteCommand1(0xc0);
LCD_WriteCommand2(0xc0);
LCD_WriteCommand1(0x3f); //开显示
LCD_WriteCommand2(0x3f);
for (j=0;j<8;j++) //清屏
LCD_WriteCommand1(0xB8+j); //清左半屏
LCD_WriteCommand1(0x40);
for (i=0;i<64;i++)
LCD_WriteData1(0x00);
LCD_WriteCommand2(0xB8+j); //清右半屏
LCD_WriteCommand2(0x40);
for (i=0;i<64;i++)
LCD_WriteData2(0x00);
void DispBmp(char *buf) //显示一幅位图
int i,j;
for (j=0;j<8;j++) //显示位图
for (i=0;i<64;i++)
LCD_WriteData1(buf[(j*2)*64+i]);
for (i=0;i<64;i++)
LCD_WriteData2(buf[(j*2+1)*64+i]);
void Delay1s(unsigned char T);
void TestLCD(void)
char i;
InitLCD();
DispBmp(screen);
for (i=0;i<64;i++)
Delay1ms(50);
LCD_WriteCommand1(0xc0+i%64); //设置起始行,实现向上滚动
LCD_WriteCommand2(0xc0+i%64);
Delay1s(3);
for (;;)
DispBmp(screen1);
Delay1s(5);
DispBmp(screen2);
Delay1s(6);
InitLCD();
LCD_WriteHZ(2,1,Han); //显示16*16点阵汉字'汉'
Delay1ms(100);
LCD_WriteHZ(60,3,Zi); //显示16*16点阵汉字'字'
Delay1s(5);
2007-03-22 22:42:00     打赏
下面是主函数..因为控制液晶的部分都写在了子函数里面,主函数就显得比较简洁了...
#include "c8051f020.h"
/*void Delay1us(unsigned char us)
while (us)
_nop_(); _nop_(); _nop_(); _nop_(); _nop_();
--us;
void SYSCLK_Init (void)
int i; // delay counter
OSCXCN = 0x67; // start external oscillator with
// 18.432MHz crystal
for (i=0; i < 256; i++) ; // Wait for osc. to start up
while (!(OSCXCN & 0x80)) ; // Wait for crystal osc. to settle
OSCICN = 0x88; // select external oscillator as SYSCLK
// source and enable missing clock
// detector
// OSCICN = 0x07; //interal 16MHZ
#define PRT0CF P0MDOUT
#define PRT1CF P1MDOUT
#define PRT2CF P2MDOUT
void PORT_Init (void)
XBR0 = 0x07; // Enable SMBus, SPI0, and UART0
XBR1 = 0x00;
XBR2 = 0x44; // Enable crossbar and weak pull-ups
EMI0CF = 0x27;
EMI0TC = 0x21;
P74OUT = 0xFF;
P0MDOUT = 0x15;
P1MDOUT |= 0x3C; //P1.2-P1.5推挽输出
P1 &= 0xc3; //P1.2-P1.5=0
void SPI0_Init (void)
SPI0CFG = 0x07; // data sampled on 1st SCK rising edge
// 8-bit data words
SPI0CFG|=0xC0; //CKPOL =1;
SPI0CN = 0x03; // Master mode; SPI enabled; flags
// cleared
SPI0CKR = SYSCLK/2/8000000-1; // SPI clock <= 8MHz (limited by
// EEPROM spec.)
unsigned char Count1ms;
void Timer0_Init (void)
CKCON|=0x8;
TMOD|=0x1; //16Bit
Count1ms=10;
TR0 = 0; // STOP Timer0
TH0 = (-SYSCLK/1000) >> 8; // set Timer0 to overflow in 1ms
TL0 = -SYSCLK/1000;
TR0 = 1; // START Timer0
IE|= 0x2;
void Timer0_ISR (void) interrupt 1 //1ms
TL0 = -SYSCLK/1000;
if (Count1ms) Count1ms--;
void Delay1ms(unsigned char T)
Count1ms=T;
while (Count1ms);
while (T)
Delay1ms(200);
Delay1ms(200);
Delay1ms(200);
Delay1ms(200);
Delay1ms(200);
T--;
//void Test7279(bit LoopFlag);
void TestLCD(void);
//void DispLED(char *buf);
void main (void)
WDTCN = 0xde;
WDTCN = 0xad; //关看门狗
SYSCLK_Init (); //初始化时钟
Timer0_Init(); //初始化定时器
PORT_Init (); //初始化IO口
SPI0_Init (); //初始化SPI0
CPT1CN|=0x80; //使能比较器1
REF0CN = 0x03; //使能片内参考电压
DAC0CN |= 0x80; //使能DAC0
DAC0H=0; DAC0L=0;
EA=1; //开中断
//Test7279(0);
TestLCD();
共6条 1/1 1 跳转至页
