元件例化与层次设计
Verilog HDL: Creating a Hierarchical Design
This example describes how to create a hierarchical design using Verilog HDL.
The file top_ver.v is the top level, which calls the two lower level files bottom1.v and bottom2.v.
download from: http://www.fpga.com.cn
vprim.v
top_ver.v
module top_ver (q, p, r, out);
input q, p, r;
output out;
reg out, intsig;
bottom1 u1(.a(q), .b(p), .c(intsig));
bottom2 u2(.l(intsig), .m(r), .n(out));
endmodule
bottom1.v
module bottom1(a, b, c);
input a, b;
output c;
reg c;
always
begin
c<=a & b;
end
endmodule
bottom2.v
module bottom2(l, m, n);
input l, m;
output n;
reg n;
always
begin
n<=l | m;
end
endmodule
