电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » Verilog HDL 程序举例--基本组合逻辑功能:
2007-03-29 20:31:49     打赏
7段译码器
// DESCRIPTION   :   BIN to seven segments converter
//                   segment encoding
//                        a
//                    f |   | b
//                      +---+  <- g
//                    e |   | c
//                        d
//                  Enable (EN) active                : high
//                  Outputs (data_out) active         : low
// Download from :  http://www.pld.com.cn
module bin27seg (data_in ,EN ,data_out );
	input [3:0] data_in ;
	input EN ;
	output [6:0] data_out ;
	reg [6:0] data_out ;
	always @(data_in or EN )
	begin
		data_out = 7'b1111111;
		if (EN == 1)
			case (data_in )
				4'b0000: data_out = 7'b1000000; // 0
				4'b0001: data_out = 7'b1111001; // 1
				4'b0010: data_out = 7'b0100100; // 2
				4'b0011: data_out = 7'b0110000; // 3
				4'b0100: data_out = 7'b0011001; // 4
				4'b0101: data_out = 7'b0010010; // 5
				4'b0110: data_out = 7'b0000011; // 6
				4'b0111: data_out = 7'b1111000; // 7
				4'b1000: data_out = 7'b0000000; // 8
				4'b1001: data_out = 7'b0011000; // 9
				4'b1010: data_out = 7'b0001000; // A
				4'b1011: data_out = 7'b0000011; // b
				4'b1100: data_out = 7'b0100111; // c
				4'b1101: data_out = 7'b0100001; // d
				4'b1110: data_out = 7'b0000110; // E
				4'b1111: data_out = 7'b0001110; // F
				default: data_out = 7'b1111111;
			endcase
	end
endmodule
二进制到格雷码转换
// DESCRIPTION   :  Bin to gray converter
//                  Input (DATA_IN) width : 4
module BIN2GARY (EN ,DATA_IN ,DATA_OUT );
	input EN ;
	input [3:0] DATA_IN ;
	output [3:0] DATA_OUT ;
	assign DATA_OUT [0] = (DATA_IN [0] ^ DATA_IN [1] ) && EN ;
	assign DATA_OUT [1] = (DATA_IN [1] ^ DATA_IN [2] ) && EN ;
	assign DATA_OUT [2] = (DATA_IN [2] ^ DATA_IN [3] ) && EN ;
	assign DATA_OUT [3] = DATA_IN [3] && EN ;
endmodule
二进制到BCD码转换
// DESCRIPTION   :  Bin to Bcd converter
//                  Input (data_in) width : 4
//                  Output (data_out) width : 8
module bin2bcd (data_in ,EN ,data_out );
input EN ;
output [7:0] data_out ;
reg [7:0] data_out ;
	begin
		data_out = {8{1'b0}};
		if (EN == 1)
		begin
			case (data_in [3:1])
				3'b000 : data_out [7:1] = 7'b0000000;
				3'b001 : data_out [7:1] = 7'b0000001;
				3'b010 : data_out [7:1] = 7'b0000010;
				3'b011 : data_out [7:1] = 7'b0000011;
				3'b100 : data_out [7:1] = 7'b0000100;
				3'b101 : data_out [7:1] = 7'b0001000;
				3'b110 : data_out [7:1] = 7'b0001001;
				3'b111 : data_out [7:1] = 7'b0001010;
				default : data_out [7:1] = {7{1'b0}};
			endcase
			data_out [0] = data_in [0];
		end
	end
endmodule
多路选择器(MUX)
// DESCRIPTION   :  Multiplexer
//                  Code style: used case statement
//                  Width of output terminal: 8
//                  Number of terminals: 4
//                  Output enable active: HIGH
//                  Output value of all bits when enable not active: 0
module mux(EN ,IN0 ,IN1 ,IN2 ,IN3 ,SEL ,OUT );
	input  EN ;
	input  [7:0] IN0 ,IN1 ,IN2 ,IN3 ;
	input  [1:0] SEL ;
	output [7:0] OUT ;
	reg  [7:0] OUT ;
	always @(SEL  or EN  or IN0  or IN1  or IN2  or IN3 )
	begin
		if (EN  == 0) OUT  = {8{1'b0}};
		else
			case (SEL )
				0 : OUT  = IN0 ;
				1 : OUT  = IN1 ;
				2 : OUT  = IN2 ;
				3 : OUT  = IN3 ;
				default : OUT  = {8{1'b0}};
			endcase
	end
endmodule
双向管脚(clocked bidirectional pin)
Verilog HDL: Bidirectional Pin
This example implements a clocked bidirectional pin in Verilog HDL.
The value of OE determines whether bidir is an input, feeding in inp, or a tri-state, driving out the value b.
download from: http://www.fpga.com.cn
bidir.v
module bidirec (oe, clk, inp, outp, bidir);
// Port Declaration
input   oe;
input   clk;
input   [7:0] inp;
output  [7:0] outp;
inout   [7:0] bidir;
reg     [7:0] a;
reg     [7:0] b;
assign bidir = oe ? a : 8'bZ ;
assign outp  = b;
// Always Construct
always @ (posedge clk)
begin
	b <= bidir;
	a <= inp;
end
endmodule
关键词: Verilog     程序     举例     基本     组合     逻辑     功能
2007-03-29 20:37:00     打赏
顶
顶
