共4条
网站的上载好像有点问题,能否检查一下!
错误信息:
Fatal error: Uncaught exception 'Zend_Controller_Dispatcher_Exception' with message 'Invalid controller specified (common)' in /var/www/html/www.edw.com.cn/library/Zend/Controller/Dispatcher/Standard.php:189 Stack trace: #0 /var/www/html/www.edw.com.cn/library/Zend/Controller/Front.php(889): Zend_Controller_Dispatcher_Standard->dispatch(Object(Zend_Controller_Request_Http), Object(Zend_Controller_Response_Http)) #1 /var/www/html/www.edw.com.cn/www/wwwroot/index.php(147): Zend_Controller_Front->dispatch() #2 {main} thrown in /var/www/html/www.edw.com.cn/library/Zend/Controller/Dispatcher/Standard.php on line 189
共4条
