电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » 状态机分享(转帖)
状态机分享(转帖)
2008-03-19 09:38:27     打赏
对EDA来说,状态机是一个非常重要的部分.如果能灵活地运用状态机,那么写程序就可以游刃有余了!
状态机一般分为三种类型:
Moore型状态机:次态=f(现状,输入),输出=f(现状);
Mealy型状态机:次态=f(现状,输入),输出=f(现状,输入);
混合型状态机。
Moore型与Mealy型两种状态机的不同点在于,Moore型状态机的输出信号是直接由状态寄存器译码得到,而Mealy型状态机则是以现时的输入信号结合即将变成次态的现态,编码成输出信号。
以下是我收藏的一些程序,让大家更深刻地了解!
莫尔型状态机
library ieee;
use ieee.std_logic_1164.all;
entity moore2 is port(
        clk, rst:       in std_logic;
        id:             in std_logic_vector(3 downto 0);
        y:              out std_logic_vector(1 downto 0));
end moore2;
architecture archmoore2 of moore2 is
        signal state: std_logic_vector(2 downto 0);
-- State assignment is such that 2 LSBs are outputs
constant state0: std_logic_vector(2 downto 0) := "000";
constant state1: std_logic_vector(2 downto 0) := "010";
constant state2: std_logic_vector(2 downto 0) := "011";
constant state3: std_logic_vector(2 downto 0) := "110";
constant state4: std_logic_vector(2 downto 0) := "111";
begin
moore: process (clk, rst)
        begin
                if rst='1' then
                        state <= state0;
                elsif (clk'event and clk='1') then
                        case state is
                                when state0 =>
                                        if id = x"3" then
                                                state <= state1;
                                        else
                                                state <= state0;
                                        end if;
                                when state1 =>
                                        state <= state2;
                                when state2 =>
                                        if id = x"7" then
                                                state <= state3;
                                        else
                                                state <= state2;
                                        end if;
                                when state3 =>
                                        if id < x"7" then
                                                state <= state0;
                                        elsif id = x"9" then
                                                state <= state4;
                                        else
                                                state <= state3;
                                        end if;
                                when state4 =>
                                        if id = x"b" then
                                                state <= state0;
                                        else
                                                state <= state4;
                                        end if;
                                when others =>
                                        state <= state0;
                        end case;
                end if;
        end process;
--assign state outputs (equal to state std_logics)
y <= state(1 downto 0);
end archmoore2;
library ieee;
entity moore1 is port(
end moore1;
architecture archmoore1 of moore1 is
        type states is (state0, state1, state2, state3, state4);
        signal state: states;
begin
moore: process (clk, rst)  --this process defines the next state only
        begin
                if rst='1' then
                        state <= state0;
                        case state is
                                when state0 =>
                                        if id = x"3" then
                                                state <= state1;
                                        else
                                                state <= state0;
                                        end if;
                                when state1 =>
                                        state <= state2;
                                when state2 =>
                                        if id = x"7" then
                                                state <= state3;
                                        else
                                                state <= state2;
                                        end if;
                                when state3 =>
                                        if id < x"7" then
                                                state <= state0;
                                                state <= state4;
                                        else
                                                state <= state3;
                                        end if;
                                when state4 =>
                                        if id = x"b" then
                                                state <= state0;
                                        else
                                                state <= state4;
                                        end if;
                        end case;
                end if;
        end process;
--assign state outputs concurrently;
y <= "00" when (state=state0) else
     "10" when (state=state1 or state=state3) else
     "11";
end archmoore1;
关键词: 状态机     分享     转帖     logic     vector     st
