电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 求助 arm9 实现汇编memcpy
求助 arm9 实现汇编memcpy
2008-09-16 15:34:39     打赏
急,但是对汇编不熟
请教arm 里的字对齐和半字对齐的问题还是不甚明白;
为什么要求字单元地址的低两位是00(能被4整除),半字单元地址的最低位0(能被2整除)
数据的地址必须按照这种地址要求存储么?
谁实现过能不能传给我一份
谢谢
我的邮箱:rui.bao@163.com
关键词: 求助     实现     汇编     memcpy
2008-09-17 09:21:36     打赏
我在网上下的一个程序是linux下的memcpy,看不懂汇编,
谁帮我看看在arm下能不能用,汇编厉害的帮我注释一下程序吧
谢谢了
 * linux/arch/arm/lib/memcpy.S
#include <linux/linkage.h>
#include <asm/assembler.h>
#include "constants.h"
                .text
#define ENTER   \
                mov     ip,sp   ;\
                stmfd   sp!,{r4-r9,fp,ip,lr,pc} ;\
                sub     fp,ip,#4
#define EXIT    \
                LOADREGS(ea, fp, {r4 - r9, fp, sp, pc})
#define EXITEQ  \
                LOADREGS(eqea, fp, {r4 - r9, fp, sp, pc})
 * Prototype: void memcpy(void *to,const void *from,unsigned long n);
 * ARM3: cant use memcopy here!!!
ENTRY(memcpy)
ENTRY(memmove)
                ENTER
                cmp     r1, r0
                bcc     19f       ;进位清除 r1<r0
                subs    r2, r2, #4
                blt     6f
                ands    ip, r0, #3
                bne     7f
                ands    ip, r1, #3
                bne     8f
1:              subs    r2, r2, #8
                blt     5f
                subs    r2, r2, #0x14
                blt     3f
2:              ldmia   r1!,{r3 - r9, ip}
                stmia   r0!,{r3 - r9, ip}
                subs    r2, r2, #32
                bge     2b
                cmn     r2, #16
                ldmgeia r1!, {r3 - r6}
                stmgeia r0!, {r3 - r6}
                subge   r2, r2, #0x10
3:              adds    r2, r2, #0x14
4:              ldmgeia r1!, {r3 - r5}
                stmgeia r0!, {r3 - r5}
                subges  r2, r2, #12
                bge     4b
5:              adds    r2, r2, #8
                blt     6f
                subs    r2, r2, #4
                ldrlt   r3, [r1], #4
                strlt   r3, [r0], #4
                ldmgeia r1!, {r3, r4}
                stmgeia r0!, {r3, r4}
                subge   r2, r2, #4
6:              adds    r2, r2, #4
                EXITEQ
                cmp     r2, #2
                ldrb    r3, [r1], #1
                strb    r3, [r0], #1
                ldrgeb  r3, [r1], #1
                strgeb  r3, [r0], #1
                ldrgtb  r3, [r1], #1
                strgtb  r3, [r0], #1
                EXIT
7:              rsb     ip, ip, #4
                cmp     ip, #2
                ldrb    r3, [r1], #1
                strb    r3, [r0], #1
                ldrgeb  r3, [r1], #1
                strgeb  r3, [r0], #1
                ldrgtb  r3, [r1], #1
                strgtb  r3, [r0], #1
                subs    r2, r2, ip
                blt     6b
                ands    ip, r1, #3
                beq     1b
8:              bic     r1, r1, #3
                ldr     r7, [r1], #4
                cmp     ip, #2
                bgt     15f
                beq     11f
                cmp     r2, #12
                blt     10f
                sub     r2, r2, #12
9:              mov     r3, r7, lsr #8
                ldmia   r1!, {r4 - r7}
                orr     r3, r3, r4, lsl #24
                mov     r4, r4, lsr #8
                orr     r4, r4, r5, lsl #24
                mov     r5, r5, lsr #8
                orr     r5, r5, r6, lsl #24
                mov     r6, r6, lsr #8
                orr     r6, r6, r7, lsl #24
                stmia   r0!, {r3 - r6}
                subs    r2, r2, #16
                bge     9b
                adds    r2, r2, #12
                blt     100f
10:             mov     r3, r7, lsr #8
                ldr     r7, [r1], #4
                orr     r3, r3, r7, lsl #24
                str     r3, [r0], #4
                subs    r2, r2, #4
                bge     10b
100:            sub     r1, r1, #3
                b       6b
11:             cmp     r2, #12
                blt     13f             /* */
                sub     r2, r2, #12
12:             mov     r3, r7, lsr #16
                orr     r3, r3, r4, lsl #16
                mov     r4, r4, lsr #16
                orr     r4, r4, r5, lsl #16
                mov     r5, r5, lsr #16
                orr     r5, r5, r6, lsl #16
                mov     r6, r6, lsr #16
                orr     r6, r6, r7,LSL#16
                subs    r2, r2, #16
                bge     12b
                adds    r2, r2, #12
                blt     14f
13:             mov     r3, r7, lsr #16
                ldr     r7, [r1], #4
                orr     r3, r3, r7, lsl #16
                str     r3, [r0], #4
                subs    r2, r2, #4
                bge     13b
14:             sub     r1, r1, #2
                b       6b
15:             cmp     r2, #12
                blt     17f
                sub     r2, r2, #12
16:             mov     r3, r7, lsr #24
                ldmia   r1!,{r4 - r7}
                orr     r3, r3, r4, lsl #8
                mov     r4, r4, lsr #24
                orr     r4, r4, r5, lsl #8
                mov     r5, r5, lsr #24
                orr     r5, r5, r6, lsl #8
                mov     r6, r6, lsr #24
                orr     r6, r6, r7, lsl #8
                subs    r2, r2, #16
                bge     16b
                adds    r2, r2, #12
                blt     18f
17:             mov     r3, r7, lsr #24
                ldr     r7, [r1], #4
                orr     r3, r3, r7, lsl#8
                str     r3, [r0], #4
                subs    r2, r2, #4
                bge     17b
18:             sub     r1, r1, #1
                b       6b
19:             add     r1, r1, r2
                add     r0, r0, r2
                subs    r2, r2, #4
                blt     24f
                ands    ip, r0, #3
                bne     25f
                ands    ip, r1, #3
                bne     26f
20:             subs    r2, r2, #8
                blt     23f
                subs    r2, r2, #0x14
                blt     22f
21:             ldmdb   r1!, {r3 - r9, ip}
                stmdb   r0!, {r3 - r9, ip}
                subs    r2, r2, #32
                bge     21b
22:             cmn     r2, #16
                ldmgedb r1!, {r3 - r6}
                stmgedb r0!, {r3 - r6}
                subge   r2, r2, #16
                adds    r2, r2, #20
                ldmgedb r1!, {r3 - r5}
                stmgedb r0!, {r3 - r5}
                subge   r2, r2, #12
23:             adds    r2, r2, #8
                blt     24f
                subs    r2, r2, #4
                ldrlt   r3, [r1, #-4]!
                strlt   r3, [r0, #-4]!
                ldmgedb r1!, {r3, r4}
                stmgedb r0!, {r3, r4}
                subge   r2, r2, #4
24:             adds    r2, r2, #4
                EXITEQ
                cmp     r2, #2
                ldrb    r3, [r1, #-1]!
                strb    r3, [r0, #-1]!
                ldrgeb  r3, [r1, #-1]!
                strgeb  r3, [r0, #-1]!
                ldrgtb  r3, [r1, #-1]!
                strgtb  r3, [r0, #-1]!
                EXIT
25:             cmp     ip, #2
                ldrb    r3, [r1, #-1]!
                strb    r3, [r0, #-1]!
                subs    r2, r2, ip
                blt     24b
                ands    ip, r1, #3
                beq     20b
26:             bic     r1, r1, #3
                ldr     r3, [r1], #0
                cmp     ip, #2
                blt     34f
                beq     30f
                cmp     r2, #12
                blt     28f
                sub     r2, r2, #12
27:             mov     r7, r3, lsl #8
                ldmdb   r1!, {r3, r4, r5, r6}
                orr     r7, r7, r6, lsr #24
                mov     r6, r6, lsl #8
                orr     r6, r6, r5, lsr #24
                mov     r5, r5, lsl #8
                orr     r5, r5, r4, lsr #24
                mov     r4, r4, lsl #8
                orr     r4, r4, r3, lsr #24
                stmdb   r0!, {r4, r5, r6, r7}
                subs    r2, r2, #16
                bge     27b
                adds    r2, r2, #12
                blt     29f
28:             mov     ip, r3, lsl #8
                ldr     r3, [r1, #-4]!
                orr     ip, ip, r3, lsr #24
                str     ip, [r0, #-4]!
                subs    r2, r2, #4
                bge     28b
29:             add     r1, r1, #3
                b       24b
30:             cmp     r2, #12
                blt     32f
                sub     r2, r2, #12
31:             mov     r7, r3, lsl #16
                orr     r7, r7, r6, lsr #16
                mov     r6, r6, lsl #16
                orr     r6, r6, r5, lsr #16
                mov     r5, r5, lsl #16
                orr     r5, r5, r4, lsr #16
                mov     r4, r4, lsl #16
                orr     r4, r4, r3, lsr #16
                subs    r2, r2, #16
                bge     31b
                adds    r2, r2, #12
                blt     33f
32:             mov     ip, r3, lsl #16
                ldr     r3, [r1, #-4]!
                orr     ip, ip, r3, lsr #16
                str     ip, [r0, #-4]!
                subs    r2, r2, #4
                bge     32b
33:             add     r1, r1, #2
                b       24b
34:             cmp     r2, #12
                blt     36f
                sub     r2, r2, #12
35:             mov     r7, r3, lsl #24
                orr     r7, r7, r6, lsr #8
                mov     r6, r6, lsl #24
                orr     r6, r6, r5, lsr #8
                mov     r5, r5, lsl #24
                orr     r5, r5, r4, lsr #8
                mov     r4, r4, lsl #24
                orr     r4, r4, r3, lsr #8
                subs    r2, r2, #16
                bge     35b
                adds    r2, r2, #12
                blt     37f
36:             mov     ip, r3, lsl #24
                ldr     r3, [r1, #-4]!
                orr     ip, ip, r3, lsr #8
                str     ip, [r0, #-4]!
                subs    r2, r2, #4
                bge     36b
37:             add     r1, r1, #1
                b       24b
                .align
