Electromagnetic radiation in which wavelengths lie in the range from about 1 micrometer to 1 millimeter. This radiation therefore has wavelengths just a little longer than those of visible light and cannot be seen with the unaided eye. The radiation was discovered in 1800 by William Herschel.
An infrared source can be described by the spectral distribution of power emitted by an ideal body (a blackbody curve). This distribution is characteristic of the temperature of the body. A real body is related to it by a radiation efficiency factor or emissivity which is the ratio at every wavelength of the emission of a real body to that of a blackbody under identical conditions. The illustration shows curves for these ideal blackbodies radiating at a number of different temperatures. The higher the temperature, the greater the total amount of radiation. See also Emissivity.
Radiation from blackbodies at different temperatures, shown on a logarithmic scale.
Infrared detectors are based either on the generation of a change in voltage due to a change in the detector temperature resulting from the power focused on it, or on the generation of a change in voltage due to some photon-electron interaction in the detector material. This latter effect is sometimes called the internal photoelectric effect.
Infrared techniques have been applied in military, medical, industrial, meteorological, ecological, forestry, agricultural, chemical, and other disciplines. Weather satellites use infrared imaging devices to map cloud patterns and provide the imagery seen in many weather reports. Infrared imaging devices have also been used for breast cancer screening and other medical diagnostic applications. In most of these applications, the underlying principle is that pathology produces inflammation, and these locations of increased temperature can be found with an infrared imager. Airborne infrared imagers have been used to locate the edge of burning areas in forest fires. See also Infrared imaging devices; Remote sensing.
