电子产品世界 » 论坛首页 » 活动中心 » 合作大赛 » vm_graphic_create_layer(转)
2010-09-03 09:57:15     打赏
VMINT vm_graphic_create_layer(
VMINT x,
VMINT y,
VMINT width,
VMINT height,
VMINT trans_color
Description
Create layer.layer is the simulation for LCD.
创造层,这里的层就相当于LCD(显示屏)的模拟
using this api, user can create two layers at most, and user needn't to require additional memory for it.
使用该API,用户最多可以创建两层,且无须为该函数申请额外的内存
layer 0: same with LCD's size and position. it means, top left coordination must be (0,0), width = screen width and height = screen height
第0层(也即基层)和LCD的大小,位置相同,也就是说,左上角坐标必须为(0,0),宽等于屏幕宽度,高等于屏幕高度
layer 1: user can set the opacity, position,size(can not larger than LCD's size).
第1层:用户可以设置不透明度(即所谓的Alpha值),大小(不能大于LCD的尺寸)
the two layers can be merged with the appointed opacity
这两层可以用指定的不透明度来合并
Parameters(参数)
Parameters Description 参数描述
VMINT x [IN]x_top left coordination 左上的X坐标
VMINT y [IN]y_top left coordination 左上的Y坐标
VMINT width [IN] the width of the layer, the unit:pixel 层的宽度,单位:像素
VMINT height [IN]the height of the layer, the unit:pixel层的高度,单位:像素
VMINT trans_color [IN]the transparent color. -1 means no transparent color. 透明颜色,-1表示没有透明色
Returns
if succeed, return the layer handle, if fail, return the error code
如果调用成功,返回层句柄,如果失败,返回错误代码
Example 举例
VMINT layer_hdl[2] = {0};
layer_hdl[0] = vm_graphic_create_layer(0, 0, vm_graphic_get_screen_width(), vm_graphic_get_screen_height(), VM_NO_TRANS_COLOR);
//user can draw on the layer
vm_graphic_line_ex( layer_hdl[0],0,0,100,100);
// when need to show it to the LCD
vm_graphic_flush_layer( layer_hdl[0], 1);
//when no more use the layer, delete it
vm_graphic_delete_layer(layer_hdl[0]);
File
vmgraph.h
须包含头文件:vmgraph.h
本函数由VRE论坛http://vre.net.ru翻译,如有疑问,请加群103430901讨论,欢迎指出错误~
关键词: graphic     create     layer     VMIN
