电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » Tornado相关补丁
共4条 1/1 1 跳转至页
Tornado相关补丁
2003-11-07 18:41:25     打赏
https://secure.windriver.com/cgi-bin/windsurf/downloads/dispProdList.cgi?productid=2 PATCHES Identifier Required Name Headline Product Version lmUpg5_0 Optional The Daylight Savings Patch Daylight Savings Fix for Win95, WinNT and Unix License Manager Tornado 1.0.1 SPR 85962 Optional project migration tool patch Fix SPRs related to project migration tool present in Tornado 2.2 Tornado 2.2 SPR#71844 Mandatory SA/XScale 2.1.0 and 2.1.1 split-by-reloc not working SA/XScale 2.1.0 and 2.1.1 split-by-reloc not working Tornado 2.1 T21SH-CP1 Mandatory Tornado 2.1 for SuperH cumulative patch 1 Tornado 2.1 for Hitachi SuperH (SH) cumulative patch 1 Tornado 2.1 t221-pf-cp1 Optional Tornado Project Facility Cumulative Patch 1 A cumulative patch for many Software Problem Report (SPRs) related to Project Facility. Tornado 2.2.1 T22CP1 Optional Tornado 2.2 Cumulative Patch 1 "CP-1" Fixes for 236 SPRs present in Tornado 2.2. Tornado 2.2 T2CP1 Optional Tornado 2.0 Cumulative Patch 1 Cumulative Patch 1 Tornado 2.0 T2CP2 Optional Tornado 2.0 Cumulative Patch 2 Cumulative Patch 2 Tornado 2.0 T2CP3 Optional Tornado 2.0 Cumulative Patch 3 Cumulative Patch 3 Tornado 2.0 T2CP4 Mandatory Tornado 2.0 Maintenance Update (Cumulative patch 4 aka Tornado 2.0.2) Tornado 2.0 Maintenance Update (Cumulative patch 4 aka Tornado 2.0.2) Tornado 2.0 91095 Optional arpresolve timer problem T2.1.2-MIPS arpresolve timer may wrap around causing up to a 20 minute delay Tornado 2.1 91093 Optional arpresolve timer problem T2.1-PPC arpresolve timer may wrap around causing up to a 20 minute delay Tornado 2.1 91092 Optional arpresolve timer problem T2.0-CP3 arpresolve timer may wrap around causing up to a 20 minute delay Tornado 2.0 91069 Optional arpresolve timer problem T2.0-CP2 arpresolve timer may wrap around causing up to a 20 minute delay Tornado 2.0 91068 Optional arpresolve timer problem T2.0-PPC405 arpresolve timer may wrap around causing up to a 20 minute delay Tornado 2.0 91007 Optional arpresolve timer problem T2.0.2 arpresolve timer may wrap around causing up to a 20 minute delay Tornado 2.0.2 90451 Optional PowerPC 440GX Extends Tornado 2.2.1 PPC440 architecture to support 440GX processor Tornado 2.2.1 90073 Optional Tornado 2.2.1 Cache Library for Renesas SH7710 Tornado 2.2.1 Cache Library for the Renesas SH7710 processor. Tornado 2.2.1 89900 Optional VxWorks 5.5.1 patch for au1xxx family: Errata 27 buffer flush, mcastRcv and AuEnd auto negotiation issues Tornado 2.2.1/VxWorks 5.5.1 patch for au1xxx family, fixes SPRs 89900, 88772, 90111, and 86758 VxWorks 5.5.1 89673 Optional VxWorks 5.5.1 patch for mti20kx family: Architecture Family support mti20kx Architecture Family Support for VxWorks 5.5.1 VxWorks 5.5.1 89608 Optional XSCALE Cache/MMU Support for P and X bits Current implementation of Xscale MMU does not support the 'P' bit and manages the 'X' bit improperly. VxWorks 5.5.1 89420 Mandatory t221-patch89420 Fix for Windows Full Simulator ULIP initialization. Tornado 2.2.1 89135 Optional Tornado 2.2.1 for NEC MIPS Vr7701 architecture patch Add support for NEC MIPS Vr7701 processor family. Tornado 2.2.1 88417 Mandatory Tornado 2.2.1 Cache Library Fix for Toshiba TX49xx Tornado 2.2.1 Cache Library fix for the Toshiba Tx49xx family of processors. Tornado 2.2.1 85962 Optional project migration tool patch Fix SPRs related to project migration tool present in Tornado 2.2 Tornado 2.2 81285 Optional Write-through cache support for ARM920t, ARM920t t, ARM940t and ARM940t t Write-through cache support patch for ARM920t, ARM920t_t, ARM940t and ARM940t_t in tornado2.2 Tornado 2.2 80964 Optional PPC405GPr support added to Walnut BSP Support for Sycamore board (PPC405GPr) added to Walnut BSP Tornado 2.2 80449 Optional wrMdpPro8xx BSP update Improved support for 128 MB SDRAM; MAC address fix VxWorks 5.5 79795 Mandatory dosFs 2.2 patch x86 Update for Tornado 2.0.2 x86. dosFs2.2 for T2.0.2. Tornado 2.0.2 79569 Mandatory dosFs 2.2 patch PPC dosFs2.2 patch for Tornado 2.0.2 PPC; PPC860, PPC403, PPC603, and PPC604. Tornado 2.0.2 79505 Optional Patch for SPR 79505 MIPS32 vr41xxx vxWorks runtime patch to resolve SPR 79505. VxWorks 5.5 78953 Mandatory Windows Simulator update Configuring the Windows Simulator from the GUI fails for the following CDs: TDK-13990-ZC-00, TDK-14402-ZC-00, TDK-13976-ZC-00 Tornado 2.1 73141 Mandatory When compiling with the "mstrict-align" flag, gcc 2.7.2 generates floating point instructions for certain operations on long long types in dosFsLib.c This patch fixes a number of other SPRs present in dosfs2.0. Tornado 2.0 72107 Optional vxSim 2.1.X breakpoint problem vxSim 2.1.X breakpoint problem Tornado 2.1 70499 Optional ARM wrSbcArm7 use dip switches for MAC address wrSbcArm7 BSP needs unique MAC address Tornado 2.1 70400 Mandatory Mandatory update for dosFs 2.0 for Tornado 2.1 for PPC gcc: when compiling with '-mstrict-align' flag, gcc 2.96 generates floating-point instructions using FP registers registers registers Tornado 2.1 70253 Optional i8250 Device Driver i8250 serial problem caused by not resetting IER Register. Tornado 2.0 69385 Optional Tornado 2.0.2 fei82557End.c update to the T2.0.2 Driver Set - June 2001 This patch contains several fixes to fei82557End.c driver that was released in the Tornado 2.0.2 and the T2.0.2 Driver Set - June 2001. See the description for a list of defects corrected in this driver. Tornado 2.0.2 69299 Optional rtext-src-patch system loses mbufs and never recovers them back even after the test is stopped Tornado 2.0 69093 Optional dec21x40End (mcp750) patch: Board fails to boot after installing June 2001 Drivers update DEC ethernet driver dec21x40 in new comp_drv uses wrong physical address Tornado 2.0.2 68958 Optional ARM 946e Cache and MMU support ARM 946E cache support code faulty Tornado 2.1 68322 Optional Networks patch bundle #1 for T2.0.2 ipDetach() fails in T202 for NPT devices Tornado 2.0.2 67993 Optional taskSpawn tasks created with taskSpawn lose passed parameters beyond the 8th argument. Tornado 1.0.1 67953 Mandatory T2CP4 for PPC405 Tornado 2.0 Cumulative Patch 4 for PPC 405 Tornado 2.0 67917 Optional Win32 and Sun0S Simulator Fixes Tornado 2.0.2 67367 Optional Tornado 2.0.2 WTX Fixes Memory management problems in Tornado 2.0 and Tornado 2.0.2 WTX implementation Tornado 2.0.2 67174 Mandatory DHCP Patch SPR# 64194: Build failure when DHCP client and server combined SPR# 67174: DHCP client gets a wrong netmask and subnetmask after booting. Tornado 2.0.2 64615 Mandatory dosfs 2.0 patch for Tornado 2.0.2 DosFs2.0 tries to overwrite files that are more recent in Tornado 2.0.2 Tornado 2.0.2 63908 Optional arpresolve timer problem T2.0 arpresolve timer may wrap around causing up to a 20 minute delay Tornado 2.0 63876 Optional DP83932 SONIC END Driver Fixes sn83932End driver fails to set and clear END object flags appropriately Tornado 2.0.2 63602 Mandatory dosFs2 for MIPS R4650 from patched asmips. DosFs2 for MIPS R4650 from patched asmips. Tornado 2.0 63504 Mandatory Wind Web Server for MIPS R4650 from patched asmips. Wind Web Server for MIPS R4650 from patched asmips. Tornado 2.0 63290 Mandatory WindNet PPP Cumulative Patch #3 WindNet PPP 1.0 cumulative patch #3 Tornado 2.0 63289 Mandatory WindNet PPPoE cumulative Patch Incorrect payload length in PPPoE header Tornado 2.0 63047 Mandatory PJworks from patched MIPS assembler PJWorks for MIPS R4650 from patched asmips. Tornado 2.0 62517 Mandatory Tornado 2.0 Windows 2000 patch On a Windows 2000 host with SP1, "RPCExit Extra call" dialog box pops-up duing the initialization of Tornado IDE . . . NOTE: If you have Tornado 2.0.2 or T2CP4 (Tornado 2.0 Cumulative patch 4) you do not require this patch. Tornado 2.0 30561-t2.0.2 Mandatory patch-SPR30561-t2.0.2 Prevent DOS attack on FTP server Tornado 2.0.2 30561-t2.0 Mandatory patch-SPR30561 Prevent DOS attack on FTP server Tornado 2.0 30241 Optional TFFS & M-Systems' Millennium or 32MB DiskOnChip chips Fix for TFFS & M-Systems' latest Millennium or 32MB DiskOnChip chips Tornado 2.0 28595 Optional Tornado 2.0 version of dataCachePatch.obj. dataCachePatch.out is incompatible with tornado 2. Tornado 2.0 28245 Optional 12-hr Reporting, End of DST, and atoi() Null Termination Fixes __getDstInfo atoi calls need byte for the terminating null character. ansiTime.c Tornado 1.0.1 27957 Optional Fix for PowerPC variable argument handling gcc: ccppc : printf() will fail when passed mixed floating point and string arguments Tornado 2.0 27505-2 Optional MIPS-R3000 restoreVolatile() k0 Register Corruption k0 may be overwritten if an interrupt occurs within excIntStub Tornado 2.0 27189 Optional POSIX timer settime() & timer gettime() ovalue->it value The POSIX timer functions timer_settime and timer_gettime should return the same value (TSR130937) Tornado 1.0.1 26903 Optional MIPS R3000 restoreVolatile k0 register corruption k0 may be overwritten if an interrupt occurs within excIntStub Tornado 1.0.1 26802 Mandatory PowerPC patch for windExit. T101 PPC: windExit from task level does not unlock interrupts while working the Work Q. Tornado 1.0.1 26510 Mandatory intLock Non-cacheable Memory-mapped Registers Tornado 1.0.1 25893 Mandatory PowerPC Corruption of User-defined Type Returned from Function and 32-bit Branch Patch 22767 is broken. Tornado 1.0.1 25552 Optional Bootstrap loader file vxld.bin for Solaris 2.5.1 A feasible method of creating an x86 vxworks boot disk is not available from Solaris hosts. Tornado 2.0 25545 Optional Memory Leak on the sysUpTime Variable of the System MIB memory leak when snmpget i s done on the sysUpTime. Tornado 1.0.1 24604 Mandatory Tornado 1.0.1 for MIPS sigCtxSave. Tornado 1.0.1 24397 Mandatory SENS 1.1 ARP Patch SENS1.1: target does not respond to ARP requests for proxy entries created with arpAdd (host,eadr,ATF_PUBL) Tornado 1.0.1 24223 Mandatory 80x86 Software Floating Point Exceptions Tornado 1.0.1 24065 Optional SENS1.1 i960 Shared Memory Network Fails Tornado 1.0.1 23938 Mandatory SENS 1.1 SPR 23938 Patch recvmsg() returns negative value. NOTE: This patch is recommended for all SENS 1.1 installations. Tornado 1.0.1 22610 Mandatory Tornado 1.0.1 DosFs Patch with separate memory partition (second release of 22406) dosFsDebug unresolved in patch 224 Tornado 1.0.1 21577 Mandatory SENS 1.0 ARP Request Retransmit Patch ARP requests for the same IP address are retransmitted after 1 tick instead of 1 second. Tornado 1.0.1 21254 Mandatory Tornado 1.0.1: Solaris patch for SPR 21254,20917 Tornado 1.0.1/Solaris Hosts: icons do not appear in launcher after applying various patches to Solaris. Tornado 1.0.1 21138 Mandatory Tornado 1.0.1 patch for Rad6000 sin, cos return inaccurate results for arguments less than -pi. Tornado 1.0.1 20987-2 Mandatory Tornado 1.0.1 for Rad6000: rscvme BSP spr 20987 rscvme sysBusToLocalAdrs calculates the currently mapped VME space incorrectly. Tornado 1.0.1 20987 Mandatory Tornado 1.0.1 for Rad6000: rscvme BSP spr 20987 Tornado 1.0.1 20948 Mandatory SENS tcp data corruption SENS stack Tornado 1.0.1 20894 Mandatory SPR 20894 fix VxWorks fails to build with RtxWindows 1.0 FCS on top of a PowerPC Tornado tree Tornado 1.0.1 20054-2 Mandatory memShow race condition patch Tornado 1.0.1 20054 Mandatory memShow race condition patch Tornado 1.0.1 6517 Mandatory C++ Makesymbol patch for PowerPC g++: Load fails for C++ modules with vxWorks.st image with undefined symbol __$_13Iostream_init. Tornado 1.0.1
关键词: Tornado     相关     补丁     Optional     Pa
2003-11-07 18:43:00     打赏
BSPS Identifier Headline Product Version iq80321 Intel IQ80321 Development Platform BSP Tornado 2.1 ixcdp1100 Intel ixcdp1100 BSP Tornado 2.2 ixdp2400 Intel IXDP2400 BSP Tornado 2.2 ixdp425 Intel IXDP425 BSP Tornado MdpBasic8xx MdpBasic8xx for the WR MdpBasic8xx Board - Installation key is necessary. Note: Now availabe with Tornado 2.2 on CD-ROM (26-Aug-2002) Tornado 2.0.2 MdpPro8xx MdpPro8xx for the WR MdpPro8xx Board - Installation key is necessary. Tornado 2.0.2 MdpPro8xxT MdpPro8xxT for the WR MdpPro8xxT Board - Installation key is necessary. Tornado 2.0.2 Motorola MCPN765 Motorola MCPN765 BSP (rel Aug 2001) Tornado 2.1 MPC85x FADS Motorola MPC85x FADS BSP (rel Oct 2000) Tornado 2.0 MPC86x FADS Motorola MPC86x FADS BSP (rel Oct 2000) Tornado 2.0 PCIIO80310 PCIIO80310 for the WR PCIIO80310 (a.k.a TINA) Board - Installation key is necessary. Tornado 2.1 PPMC74xx PPMC74xx for the WR PPMC7400 Board - Installation key is necessary. Tornado 2.1 PPMC750CX PPMC750CX for the WR PPMC750CX Board - Installation key is necessary. Tornado 2.0.2 PPMC7xx PPMC7xx for the WR PPMC750/755 Board - Installation key is necessary. Tornado 2.1 PPMC8260 PPMC8260 for the WR PPMC8260 Board - Installation key is necessary. Tornado 2.0.2 PPMCI80310 PPMCI80310 for the WR PPMCI80310 (Rev 2) Board - Installation key is necessary. Tornado 2.1 PPMCMIPS32 (4Kc) PPMCMIPS32 (4Kc) for the WR PPMCMIPS32 Board - Installation key is necessary. Tornado 2.1 PPMCXScale PPMCXScale for the WR PPMCI80310 (Rev 1) Board - Installation key is necessary. Tornado 2.1 Sandpoint PMC755 Motorola Sandpoint (PMC755) BSP (rel Oct 2000) Tornado 2.0 Sandpoint PMC8240/8245 Motorola Sandpoint (PMC8240 & PMC8245) BSP (rel July 2001) Tornado 2.0 Sandpoint PMC8240/8245 (Diab tools) Motorola Sandpoint (PMC8240 & PMC8245) BSP (Diab Tools) (rel Sept 2001) Tornado 2.0 SBC405GP SBC405GP for the WR SBC405GP Board - Installation key is necessary. Tornado 2.0.2 SBC6xx7xx SBC6xx7xx for the WR SBC603/740/750/755 Board - Installation key is necessary. Tornado 2.0 SBC8240 SBC8240 for the WR SBC8240 Board - Installation key is necessary. Tornado 2.0.2 SBC824x SBC824x for the WR SBC8245/8240 Board - Installation key is necessary. Tornado 2.0.2 SBC8255 SBC8255 for the WR SBC8255 Board - Installation key is necessary. Tornado 2.0.2 SBC8260 SBC8260 for the WR SBC8260 Board - Installation key is necessary. Tornado 2.0.2 SBC8260ATM SBC8260ATM for the WR SBC8260ATM Board - Installation key is necessary. Tornado 2.0.2 SBCARM7 SBCARM7 for the WR SBCARM7 Board - Installation key is necessary. Tornado 2.1 Scout Scout for the Motorola & WR Scout Board - Installation key is necessary. Tornado 2.0.2 DRIVERS Identifier Headline Product Version Drivers 2.2.1.1 Driver Patch 2.2.1.1 for Tornado 2.2.1 - September 2003 Tornado 2.2.1 PCCard Library PCCard 1.2.0-beta Tornado 2.2 PCnet-PCI END - Unsupported AMD PCnet-PCI END Driver Source Code VxWorks 5.5 T2.0 Driver Set Feb 2001 T2.0 Driver Set - February 2001 Tornado 2.0 T202 Driver Set T2.0.2 Driver Set - February 2002 Tornado 2.0.2 T202DriverSet T2.0.2 Driver Set - June 2001 Tornado 2.0.2 SAMPLE CODE Identifier Headline Product Version C++ matrix class w/ Streaming SIMD Demonstrates optimizing C/C++ code with SSE instructions VxWorks 5.5 Deadline handler using Watchdog This program demonstrates using watchdog timers to invoke deadline handlers. VxWorks Exception recovery using Signal Demonstrates using signals to allow a task to recover gracefully from an exception. VxWorks Intertask Message Queue Demo Demonstrates intertask communication using Message Queues VxWorks Intertask Mutex Semaphore Demo Demonstrate the usage of the mutual exclusion semaphore for intertask synchronization VxWorks Intertask Pipe Demo Demonstrates intertask communication using pipes VxWorks Intertask synchronization binary semaphore Demonstrates intertask synchronization using binary semaphores VxWorks Intertask synchronization counting semaphore Demonstrates task synchronization using counting semaphore VxWorks Intertask thread safe C++ queue class Demonstrates using a thread safe C++ class for interprocess comunication. VxWorks Memory Managment Show A program to display current contents of MMU sysPhysMemDesc VxWorks myProtocol An example of attaching to the MUX layer with a custom ethernet protocol. VxWorks myShell Adding adding your own CLI to the telnet server VxWorks netShowExtra Network show routines for IP input and output queues. Also for the ARP input queue. VxWorks 5.x PPC fp exception handling PowerPC floating point exception handling example VxWorks 5.x SCSI-2 Configuration Code SCSI-2 Configuration Code Tornado 2.2 wvTest.c wvTest.c - starting and stopping Windview logging programmatically using wvOn() and wvOff(). Tornado 2.2 wvviasockets.c wvviasockets.c - programmatically upload windview data using TSFS via sockets. Tornado 2.2 MISCELLANEOUS DOWNLOADS Identifier Headline Product Version src.tor2_0-vxwrappers VxWorks C++ wrapper classes (sources, headers), now unsupported, from the Tornado 2.0 release VxWorks T22BSPDriverReplacementCDs Tornado/VxWorks BSP and Device Driver Replacement CDs Tornado 2.2 Transparent Mode Driver for Tornado 2 Rev1.6 Transparent Mode Driver for Tornado 2 Rev1.6 Tornado 2.0 wrsReport Download wrsReport, version 1.1, generator package for ELM Customers. Tornado 2.2 ESD Some purchased products are available through electronic software download (ESD).
2003-11-08 21:35:00     打赏
[quote][b]以下是引用[i]woodhead在2003-11-8 9:09:00[/i]的发言:[/b] 用户名和密码? [/quote] 正式用户用license号注册登录
2003-11-08 21:37:00     打赏
[quote][b]以下是引用[i]phantom在2003-11-8 13:35:00[/i]的发言:[/b] 请问amine老大,我把补丁仔细的看了一遍,有些not Fixed的bug我们自己已经修正过来了,如果我们向WindRiver提供修改方法,是否WindRiver会提供给我们一定的好处?? [/quote] 好处可能没有, 也许你自己可发行补丁
共4条 1/1 1 跳转至页
