电子产品世界 » 论坛首页 » DIY与开源设计 » 设计工具 » 高电阻测试系统配置
高电阻测试系统配置
2011-11-21 10:01:34     打赏
我们选择使用6517A型静电计/高阻表作为这些测试配置的测量仪器,因为它能提供飞安级灵敏度,并具有综合可编程的1000V电压源。低噪声三芯同轴转接电缆将静电计[1]连接到测量室(充满惰性气体)或分子束沉积(MBD)超高真空系统。这两个装置都包括照明样本的窗口,利用激光束测量光电导率,并通过显微镜对测量过程进行目视监控。温度可以在–20°C~120°C范围调节。图1给出有关装置的结构。
We chose to use the Model 6517A Electrometer/High ResistanceSystem as the measurement instrumentation for these test config-urations because it offers femtoamp-level sensitivity and has anintegrated programmable 1000V source. Low noise triax cablesconnect the electrometer with the measurement chamber (whichis filled with inert gas) or the MBD ultra high vacuum system.Both setups have windows for illuminating the sample with alaser beam to measure photoconductivity and for visual monitor-ing of the measurement process via a microscope. The tempera-ture can be adjusted from –20°C to 120°C. The setup isillustrated in Figure 1.
图1 惰性气体
[2]光电流测量结构(左图)以及薄膜生长过程中的高真空测量结构(右图):连接静电计的样本和线缆被具有同样电势(保护)的导体所包围,以阻止漏电流。
Figure 1. Setup for photocurrent measurements in inert gas (left) and high vacuum during thin film growth (right): The sample and the cable to the electrometerinput are surrounded by a conductor at the same potential (guard) to prevent leakage currents.
   了解更多信息
     要想了解有关6517A型静电计/高阻表[3]或者吉时利其他系列数字源表的更多信息,请点击http://www.keithley.com.cn/products/localizedproducts/highresistance/6517a,或者联系吉时利公司:全国免费电话800-810-1334手机用户请拨打440-650-1334。
登录吉时利官方微博(http://weibo.com/keithley)与专家进行互动。
吉时利仪器公司(中国)市场部
(T) 8008101334,  8610 82255010,  82255011
[1] 静电计http://www.keithley.com.cn/news/prod150211
[2] 纳米科学研究实验室http://www.keithley.com.cn/re/nrl
[3] 6517A型静电计/高阻表http://www.keithley.com.cn/products/localizedproducts/highresistance/6517a
关键词: 高电阻     电阻     测试系统     配置
