用于汽车遥控的Ev1527的pic单片机软件接收解码程序,密码采用I2C总线方式存在EEPROM中-Remote control for automotive Ev1527 the pic Singlechip software decoder to receive the procedure, the password using I2C bus EEPROM in ex
LIST P=16f57
#INCLUDE "p16F5X.INC"
__CONFIG _CP_OFF&_WDT_OFF&_XT_OSC
;说明:SCL接单片机 RC0
; : SDA接单片机 RC1
;寄存器定义
BY_COUNT EQU 14H ;I2C
COUNT_T0 EQU 12H
COUNT_T1 EQU 13H
COUNT EQU 11H
STATUS EQU 3H
PORTB EQU 6H
PORTC EQU 7H
EEPROM EQU 08H
ADDR EQU 09H
BUFIN EQU 0AH
BUFOUT EQU 0BH
SLAVE EQU 0CH
TXBUF EQU 0DH
BIT EQU 0EH
DLY1 EQU 0FH
DLY2 EQU 10H
FLAG EQU 20H
IN_DATA_0 EQU 19H
IN_DATA_1 EQU 1AH
IN_DATA_2 EQU 1BH
COUNTER0 EQU 15H ;计数器
COUNTER1 EQU 16H
COUNTER2 EQU 17H
COUNTER3 EQU 18H
CAR_STATUS EQU 1CH ;
W_SHADOW EQU 1DH ;函数调用时传送参数
COUNTER EQU 1EH
DATA1 EQU 1FH ;保留四位按键信息
DEVICE_W EQU B'10100000' ;
DEVICE_R EQU B'10100001' ;
ADR_LOCK EQU 0x00 ;存储器锁门指令入口
ADR_UNLOCK EQU 0x10 ;存储器开门指令入口
DATA_2 EQU B'11001111'
DATA_1 EQU B'00100111'
DATA_U EQU B'10111000'
DATA_L EQU B'10110100'
;都为反码 与上位机通信
COMC_LOCK EQU B'11110111' ;开锁指令 00001000B
COMC_UNLOCK EQU B'11110001' ;锁门指令 00001110B
COMC_RELAY EQU B'11110010' ;继电器指令 00001101B
PORTA_S EQU B'11110001'
DI EQU 7
DO EQU 6
SDA EQU 1
SCL EQU 0
ACKF EQU 0
;定义管脚
#define STUDY PORTC,6
#define SIGNAL PORTC,3
#define LIGHT PORTC,5
ORG 00H
GOTO INT_INIT
BSTART
BSF PORTC,SDA
BSF PORTC,SCL
MOVLW B'11001000'
TRIS PORTC
NOP
NOP
NOP
NOP
NOP
NOP
BCF PORTC,SDA
NOP
NOP
NOP
NOP
NOP
BCF PORTC,SCL
NOP
NOP
RETLW 0
BSTOP
BCF PORTC,SDA
MOVLW B'11001000'
TRIS PORTC
BCF PORTC,SDA
NOP
NOP
NOP
BSF PORTC,SCL
NOP
NOP
NOP
BSF PORTC,SDA
NOP
NOP
BCF PORTC,SCL
NOP
NOP
RETLW 0
TX
MOVLW D'8'
MOVWF BIT
TXLP BCF EEPROM,DO
BTFSC TXBUF,7
BSF EEPROM,DO
CALL BITOUT
RLF TXBUF,1
DECFSZ BIT,1
GOTO TXLP
CALL BITIN
BTFSC EEPROM,DI
BSF PORTC,ACKF
RETLW 0
RX
CLRF BUFIN
MOVLW D'8'
MOVWF BIT
BCF STATUS,0
RXLP RLF BUFIN,1
BCF BUFIN,0
CALL BITIN
BTFSC EEPROM,DI
BSF BUFIN,0
DECFSZ BIT
GOTO RXLP
NOP
RETLW 0
BITOUT
MOVLW B'11001000'
tris PORTC
BTFSS EEPROM,DO
GOTO BITLOW
BSF PORTC,SDA
GOTO CLKOUT
BITLOW BCF PORTC,SDA
CLKOUT BSF PORTC,SCL
NOP
NOP
NOP
NOP
BCF PORTC,SCL
RETLW 0
BITIN
BSF EEPROM,DI
MOVLW B'11001010'
TRIS PORTC
BSF PORTC,SCL
NOP
NOP
NOP
NOP
NOP
BTFSS PORTC,SDA
BCF EEPROM,DI
BCF PORTC,SCL
RETLW 0
;延时1s
DELAY_1S: ;延时1s
MOVLW 04H ;3+1
MOVWF COUNTER1
MOVLW 0AH ;10
MOVWF COUNTER2
MOVLW 031H ;49
MOVWF COUNTER3
;49*5+(256*5+5)*10+[(256*5+5)*256+5]*3+10=1,000,000us
DELAY_1S_WAIT
NOP
NOP
DECFSZ COUNTER3,F
GOTO DELAY_1S_WAIT
NOP
NOP
DECFSZ COUNTER2,F
GOTO DELAY_1S_WAIT
NOP
CLRWDT
DECFSZ COUNTER1,F
GOTO DELAY_1S_WAIT
;DECFSZ COUNTER0,F
;GOTO DELAY_WAIT
DELAY_RET
RETLW 0
DELAY_10MS
MOVLW D'13'
MOVWF DLY1
MOVLW 0FFH
MOVWF DLY2
LP0 DECFSZ DLY2,1
GOTO $-1
DECFSZ DLY1,1
GOTO $-5
RETLW 0
WR_EEPROM
BTFSC FLAG,1
GOTO OUT1
MOVLW B'00000000'
TRIS PORTC
CLRF PORTC
CLRF PORTC
MOVLW B'10100000'
MOVWF SLAVE
MOVLW 13H
MOVWF FSR ;IN_DATA_0地址
MOVLW B'10101100'
MOVWF BUFOUT
CLRF ADDR
CALL BSTART
MOVF SLAVE,0
MOVWF TXBUF
CALL TX
MOVF ADDR,0
MOVWF TXBUF
CALL TX
MOVF INDF,0
MOVWF TXBUF
CALL TX
INCF FSR
MOVF INDF,0
MOVWF TXBUF
CALL TX
INCF FSR
MOVF INDF,0
MOVWF TXBUF
CALL BSTOP
OUT1 RETLW 0
XIANSHI
MOVLW 08H
MOVWF COUNT
LOOP BTFSC BUFIN,7
BSF PORTC,5
CALL DELAY_1S
BCF PORTC,5
CALL DELAY_1S
RLF BUFIN,1
DECFSZ COUNT,1
GOTO LOOP
BCF PORTC,5
RETLW 0
;25ms计时子程序
DELAY_25
MOVLW 20H
MOVWF COUNT_T0
DELAY CLRWDT
MOVLW 0FFH
MOVWF COUNT_T1
DELAY1 DECFSZ COUNT_T1,1
GOTO DELAY1
DECFSZ COUNT_T0,1
GOTO DELAY
RETLW 0
;250ms计时子程序
DELAY_250
MOVLW 0F2H
MOVWF COUNT_T0
DELAY2 CLRWDT
MOVLW 0FFH
MOVWF COUNT_T1
DELAY21 NOP ;内层循环1024us
DECFSZ COUNT_T1,1
GOTO DELAY21
DECFSZ COUNT_T0,0
GOTO DELAY2
RETLW 0
;主程序开始
ORG 100H
INT_INIT
BANKSEL PORTC
MOVLW B'11001000'
TRIS PORTC
CLRF PORTC
CLRF FLAG
MOVLW 00H
MOVWF IN_DATA_0
MOVWF IN_DATA_1
MOVWF IN_DATA_2
MOVWF COUNTER
MOVWF COUNTER0
MOVWF COUNTER1
MOVWF COUNTER2
SIGNAL_SERVICE ;COUNTERX 计数器分配混乱,需要调整
BTFSS SIGNAL
GOTO SIGNAL_RET
CLRF COUNTER0
SIGNAL_SYN_HIGH
CLRWDT
BTFSS SIGNAL
GOTO SIGNAL_SYN_HIGH_TEST
INCF COUNTER0,F
BTFSS STATUS,Z
GOTO SIGNAL_RET
SIGNAL_SYN_HIGH_TEST ;210us
MOVLW D'30' ;30?这个取值需要重新计算
SUBWF COUNTER0,W
BNC SIGNAL_RET
CLRF COUNTER1
SIGNAL_SYN_LOW
GOTO $+1
GOTO $+1
GOTO $+1
GOTO $+1
GOTO $+1
GOTO $+1
CLRWDT
BTFSC SIGNAL
GOTO SIGNAL_RET
DECFSZ COUNTER1,F
GOTO SIGNAL_SYN_LOW
SIGNAL_SYN_LOW_WAIT
CLRWDT
BTFSS SIGNAL
GOTO SIGNAL_SYN_LOW_WAIT
MOVLW D'24'
MOVWF COUNTER2
SIGNAL_PERIOD_START
CLRF COUNTER0
CLRF COUNTER3
SIGNAL_PERIOD_LOW_WAIT
CLRWDT
GOTO $+1
BTFSC SIGNAL
GOTO SIGNAL_PERIOD_HIGH
INCFSZ COUNTER0,F
GOTO SIGNAL_PERIOD_LOW_WAIT
GOTO SIGNAL_RET
SIGNAL_PERIOD_HIGH ;6个时钟周期
CLRWDT
BTFSS SIGNAL
GOTO SIGNAL_PERIOD_VALUE_JUDGE
INCFSZ COUNTER3,F
GOTO SIGNAL_RET
MOVLW D'20' ;高电平小于120us 退出
SUBWF COUNTER3,W
BNC SIGNAL_RET
BCF FLAG,0
MOVLW D'80' ;高电平大于120us 小于480us判断为‘0’
SUBWF COUNTER3,W ; 大于480us 判断为‘1’
BNC SIGNAL_PERIOD_VALUE_SAVE
BSF FLAG,0
RLF IN_DATA_0,F
RLF IN_DATA_1,F
RLF IN_DATA_2,F
BCF IN_DATA_0,0
BTFSC FLAG,0
BSF IN_DATA_0,0
DECFSZ COUNTER2,F
GOTO SIGNAL_PERIOD_START
BSF LIGHT ;收到信号,闪3下
CALL DELAY_1S
BCF LIGHT
CALL DELAY_1S
BSF LIGHT
CALL DELAY_1S
BCF LIGHT
CALL DELAY_1S
BSF LIGHT
CALL DELAY_1S
BCF LIGHT
CALL DELAY_1S
MOVLW 0FH
ANDWF IN_DATA_0,W
MOVWF DATA1 ;屏蔽低4位,保留地址码值
MOVLW 0F0H
ANDWF IN_DATA_0,F ;屏蔽高4位,保留键码值
;对接收到的数据进行处理,若为初始化(学习),则将数据存入EEPROM;否则,给出开锁或者上锁信号
SIGNAL_PROCESSING
BCF PORTC,0
BCF PORTC,1
;BTFSC STUDY
;GOTO WRITE
MOVLW 40H
MOVWF FSR
MOVLW 03H ;3次读
MOVWF BY_COUNT
CLRF PORTC
MOVLW B'10100000'
MOVWF SLAVE
CLRF ADDR
CALL BSTART
MOVF SLAVE,0
MOVWF TXBUF
CALL TX
MOVF ADDR,0
MOVWF TXBUF
CALL TX
CALL BSTART
MOVLW B'10100001'
MOVWF TXBUF
CALL TX
RBYTE CALL RX
MOVF BUFIN,0
MOVWF INDF
INCF FSR
DECFSZ BY_COUNT,1
GOTO LOWACK
BSF EEPROM,DO
CALL BITOUT
CALL BSTOP
GOTO OUT2
LOWACK BCF EEPROM,DO
CALL BITOUT
CALL XIANSHI
GOTO RBYTE
NOP
OUT2 MOVLW B'11001000'
TRIS PORTC
BSF LIGHT ;读完闪1次
CALL DELAY_1S
BCF LIGHT
GOTO CHECK_AD
WRITE CALL WR_EEPROM
BSF FLAG,1
BSF LIGHT
CALL DELAY_250
BCF LIGHT ;进入写EEPROM
GOTO EXIT
;比较地址码
CHECK_AD MOVLW 40H
MOVWF FSR
MOVF IN_DATA_0,0
XORWF INDF,0
BTFSS STATUS,Z
GOTO EXIT
INCF FSR,1
MOVF IN_DATA_1,0
XORWF INDF,0
BTFSS STATUS,Z
GOTO EXIT
INCF FSR,1
MOVF IN_DATA_2,0
XORWF INDF,0
BTFSS STATUS,Z
GOTO EXIT ;地址码不对,跳出
;检查指令
GOTO OPEN
DONE MOVF DATA1,0
XORLW 00H
BTFSS STATUS,Z
GOTO OPEN
GOTO EXIT
OPEN BSF PORTC,5
CALL DELAY_250
BCF PORTC,5
CALL DELAY_250
BSF PORTC,5
CALL DELAY_250
BCF PORTC,5
EXIT
NOP
SIGNAL_RET
GOTO SERVICE_END
SERVICE_END
NOP
NOP
BTFSC SIGNAL ;SIGNAL =1外部有信号输入
GOTO SIGNAL_SERVICE
NOP
NOP
NOP
NOP
NOP
NOP
GOTO SERVICE_END
END
深圳市晶美润科技有限公司
销售工程师:尤竹旺
QQ:820693572
0755 – 88351224
13728989126
| OrangePiZero2W系统被打赏¥33元 | |
