电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » eeprom
共4条 1/1 1 跳转至页
eeprom
2011-12-24 16:51:07     打赏
大家帮忙看下代码,为什么写入的是数据是05,而读出来是别的数据?
下面是代码请大家帮忙看看!
void statr()
 SDA=1;
 delay1();
 SCL=1;
 delay1();
 SDA=0;
 delay1();
void stop()
 SDA=0;
 delay1();
 SCL=1;
 delay1();
 SDA=1;
 delay1();
void acknow()
 SCL=1;
 delay1();
 if(SDA==0)
 delay1();
 SCL=0;
 delay1();
void write1byte(unchar addr)
 unchar run;
 run=addr;
 for(x=0;x<8;x++)
 SCL=0;
 delay1();
 run=run<<1;
 SDA=CY;
 delay1();
 SCL=1;
 delay1();
 SCL=0;
 delay1();
 SDA=1;
 delay1();
unchar read1byte()
 unchar com;
 for(x=0;x<8;x++)
  SCL=1;
  delay1();
  com=com<<1|SDA;
  SCL=0;
  delay1();
 return(com);
main()
statr();
  write1byte(0xa0);
  acknow();
  write1byte(0x00);
  acknow();
  write1byte(0x04);
  acknow();
  write1byte(0x05);
  acknow();
  stop();
  delay(100);
  statr();
  write1byte(0xa0);
  acknow();
  write1byte(0x00);
  acknow();
  write1byte(0x04);
  acknow();
  statr();
  write1byte(0xa1);
  acknow();
  aa=read1byte();
  stop();
  P2=0X01;
  //P1=0XFD;
  P37=1;
  P0=tabol[aa];
  P37=0;
  delay(50);
 while(1);
关键词: eeprom     delay1
2011-12-25 00:20:07     打赏
2011-12-26 22:14:29     打赏
void delay1()
void delay(unsigned int z)
 unsigned int x,y;
 for(x=z;x>0;x--)
  for(y=120;y>0;y--);
2011-12-27 23:04:35     打赏
又看了一遍图,是啊,地址写错了,真糟糕!
多谢楼上zhengningwei提醒啊!
共4条 1/1 1 跳转至页
