电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » QPSK载波同步环的matlab仿真
QPSK载波同步环的matlab仿真
2011-12-27 17:31:53     打赏
原理参照的是《通信中的同步技术及应用》一书的119页的框图
但是环路始终无法锁定,希望高人指点,坐等答复……
程序如下:
% %                 QPSK 载波恢复环
clc
close all;
clear all;
%**** Initialize the Varibales  ******
fs=1e8;    %采样频率:100MHz
ts=1/fs;
fc=5e6;    %载频:5MHz
fd=5e5;    %码速率:500KHz
T=0.0001;  %分析时间长度
num = 1e4;
SNR = 100;
N_S= randi([0 1],1,2000); %基带二进制序列
psk4= strPSK4_modu(N_S,fs,fc,fd,T); %产生QPSK信号
qpskdata= psk4(1:num);
data = awgn(qpskdata,SNR);
local_fc = 5000200;          % local signa  delta_fc:[-200 200]
n = fs/fc;
m = [0:n-1];
nf = floor(num/n);% divide input into nf 1ms block signal
temp = 0;
frame = 0;
phase = 0;
Q_sum=0;
I_sum=0;
Q_T=[];
I_T=[];
% ***** Compute the PLL coefficients for the PLL_IN phase ******
[c1,c2] = calculatePLLCoef(0.707,30);   %噪声带宽增大,跟踪精度降低,而跟踪时间减小
for frame=1:nf
     %   ***** Generate local sine and consine replica  *****************
     expcol = exp(1i*(2*pi*local_fc*ts*m));
     sine = imag(expcol);
     cosine = real(expcol);
     %   ***** Take 1ms of data from the input data  *********************
     x = data((1:n)+((frame-1)*n));
     %   **** Convent the signal down to baseband  ***********************
     x_sine = x.*sine;
     x_cosine = x.*cosine;
     %   ****  Realize integral operation to code period(200) *****************
     if(length(Q_T)==200)
         Q_sum=sum(Q_T);
         Q_T=[];
     else
         Q_T=[Q_T x_sine];
     end
     if(length(I_T)==200)
         I_sum=sum(I_T);
         I_T=[];
     else
         I_T=[I_T x_cosine];
     end
     %   **** Code and Phase discriminators *************************
        phase_discri(frame) = sign(Q_sum)*I_sum-sign(I_sum)*Q_sum;
         % ******* Phase lock loop (PLL) ************
        temp = temp+c2*phase_discri(frame);  % integral branch
        dfrq = c1*phase_discri(frame)+temp;  % loop filter
        local_fc = local_fc-dfrq/(2*pi*ts);  % change local frequency(must be  -)
%         phase = 2*pi*local_fc*ts+phase;    % make the phase of each block
        dfrq_frame(frame) = local_fc;        % save the changes of local frequency
end
plot(dfrq_frame);
hold on
plot([1:length(dfrq_frame)],fc,'r.');
legend('PLL tracking frequency','Real input frequency');
关键词: 载波     同步     matlab     仿真     local
