电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » 1-Wire File Structure
2012-04-04 07:27:37     打赏
关键词: OWFS, 1-Wire file structure, 1-Wire file, file system, file systems, iButton file system, ibuttons, 1wire
Abstract: This application note discusses the 1-Wire® File Structure (OWFS). The OWFS provides a directory structure for data residing in 1-Wire devices including iButtons. It allows named files to be randomly accessed as they are on other file systems. This document provides the full specification including bitmap files for large capacity 1-Wire devices, multiple subdirectories, extended file attributes, and other useful constructs such as files spanning multiple devices.
 1-Wire File Structure.pdf
关键词: 1-Wire     Structure
