电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Single-Wire Serial Bus Carries Isolated
Single-Wire Serial Bus Carries Isolated Power and Data
2012-04-04 08:09:58     打赏
关键词: serial bus, isolation barrier, galvanic isolation, transformer isolation, optoisolators
Abstract: An interface circuit uses the Dallas Semiconductor 1-Wire serial bus to provide isolated power and bidirectional communications between a master (MCU) and a sensing element.
 Single-Wire Serial Bus Carries Isolated Power and Data.pdf
关键词: Single-Wire     Serial     Carrie
