电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Reading and Writing 1-Wire® Devices Thro
Reading and Writing 1-Wire® Devices Through Serial Interfaces
2012-04-04 10:51:17     打赏
关键词: 1-Wire, OneWire, iButton, iButtons, serial port, serial communication, uart, 8253, 8250, 1wire
Abstract: This application note presents the electrical aspect of the 1-Wire protocol for new and legacy devices. A special section explains how to determine appropriate timing parameters for a network comprised of both old and new 1-Wire slaves. The 1-Wire Master Concepts section provides references to other documents that discuss 1-Wire masters in detail and to the related software.
 Reading and Writing 1-Wire® Devices Through Serial Interfaces.pdf
关键词: Reading     Writing     1-Wire     De
