电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Understanding Flash ADCs
2012-04-09 20:13:19     打赏
关键词: flash ADCs, analog to digital converters, convertors, analog digital, a to d,A/D, sigma-delta, SAR, successive approximation register, flash ADC, pipelined ADC, subranging ADC, sparkle code, metastability, clock jitter
 Abstract: Flash analog-to-digital converters, also known as parallel ADCs, are the fastest way to convert an analog signal to a digital signal. Flash ADCs are ideal for applications requiring very large bandwidth, but they consume more power than other ADC architectures and are generally limited to 8-bit resolution. This tutorial will discuss flash converters and compare them with other converter types.
  Understanding Flash ADCs.pdf
关键词: Understanding     Flash
