Precision DAC and Watchdog Improve Analog Output Safety
关键词: uP supervisor, microprocessor supervisor, analog io, DAC, optocoupler, digital analog converter, programmable logic controller, PLC, data acquisition
Abstract: Using a DAC and a microprocessor supervisor, the system safety can be improved in industrial controllers, programmable-logic controllers (PLC), and data-acquisition systems. The analog output is set to zero-scale (or pin-programmable midscale) when a microprocessor failure, optocoupler failure, or undervoltage condition occurs. A simple application is shown on how to implement this function.
Precision DAC and Watchdog Improve Analog Output Safety.pdf
有奖活动 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
