电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Digital-to-Analog Converters Are a "Bit"
Digital-to-Analog Converters Are a "Bit" Analog
2012-04-12 18:12:27     打赏
关键词: DACs, digital analog, digital to analog converter, INL, DNL, linearity, gain error, offset error, control, PLC, actuators
Abstract: Despite the popularity of digital devices, real-world signals are typically represented by analog signals. Digital control systems process analog signals by using an analog-to-digital converter (ADC) to convert analog signals to digital. Conversions back to analog signals are accomplished using a digital-to-analog converter (DAC). Maxim offers a complete line of precision DACs from 8 to 16 bits. It is important to find a DAC that meets the requirements of the application. A design engineer needs to look at parameters such as linearity, resolution, speed, and accuracy when selecting a DAC.
 Digital-to-Analog Converters Are a  Bit  Analog.pdf
关键词: Digital-to-Analog     Convert
