Part 2: Crosstalk on the Clock
关键词: noise, power supply coupling, capacitive crosstalk, grounding currents, digital crosstalk, FFT, random noise, harmonic distortion, ADC, DAC, clock, jitter, analog to digital converter, converters
Abstract: Part 2 of a series of articles explaining the effects of digital crosstalk in data converters. This article talks about noise on the clock source (jitter) and the effects on the analog-to-digital converter (ADC).
Effects of Digital Crosstalk in Data Converters.pdf
