电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » DAC and Op Amp Generate Variable Negativ
DAC and Op Amp Generate Variable Negative Control Voltage
2012-04-13 17:48:24     打赏
关键词: DACs, single supply DAC, variable negative control voltage, programmable negative voltage, positive to negative voltage translator, digital analog converter, digital to analog converters
Abstract: This design idea describes a simple circuit to generate a programmable negative control voltage. It takes the output of a single supply digital-to-analog converter (DAC) and produces a variable negative voltage. The DAC output from 0V to +2.5V is converted to 0V to -5V at the output.
 DAC and Op Amp Generate Variable Negative Control Voltage.pdf
关键词: Generate     Variable     Negativ
