电子产品世界 » 论坛首页 » 综合技术 » 测试测量 » FlexRay触发,解码和物理层测试软件包
2012-04-13 21:39:46     打赏
FlexRay触发,解码和物理层测试软件包为示波器添加了一套独特的FlexRay设计和调试工具。FlexRay触发功能可以快速定位特定的ID或消息,并在物理层信号上方直接显示解码后的数据。眼图和时序测量功能可以快速定位物理层问题。 力科集成了触发,解码和物理层测试的这个软件包能够极大缩短FlexRay测试时间。
FlexRaybus
The FlexRay trigger, decode and physical layer test package adds a unique set of tools to your oscilloscope simplifying how you design and debug your FlexRay systems. The powerful internal FlexRay trigger quickly locates specific Ids or messages and the unique overlay shows decoded data directly on top of the physical layer signal. The eye diagram and timing measurements quickly locate physical layer problems. LeCroy's integration of trigger, decode and physical layer testing shortens FlexRay testing time.
Features and Benefits
  • The most comprehensive oscilloscope-based FlexRay solution
  • Complete FlexRay Trigger Decode and Physical Layer Test in one instrument
  • Triggering and decoding of FlexRay protocol version 2.1
  • Eye diagram mask testing with error location
  • Physical layer measurement parameters for Propagation Delay, Asymmetric Delay, Truncation and Jitter
  • Supports 2.5, 5, and 10 Mb/s FlexRay signals
  • Easily view the decoded signals with an intuitive color-coded decode overlay
  • Supports triggering for
    • Frame ID (Static and Dynamic)
    • Frame Cycle Count
    • Frame Qualifiers
    • Symbols
    • Errors
  • Convenient table display with quick "zoom to byte" capability
  • Quick Search capability for specific message packets
The FlexRay trigger, decode and physical layer test package adds a unique set of tools to your oscilloscope simplifying how you design and debug your FlexRay systems and shorten testing time. The powerful internal FlexRay trigger quickly locates specific Ids or messages and the unique overlay shows decoded data directly on top of the physical layer signal. The eye diagram and timing measurements quickly locate physical layer problems.
Built-in Oscilloscope Trigger Makes Setup Easy
Isolate specific FlexRay messages with the built-in oscilloscope trigger. Since the trigger is not a FlexRay node, connection to your FlexRay bus is simplified; and no re-programming of the vehicle network is required, simply connect a differential probe to your FlexRay signal. All the triggering is done in the oscilloscope and setup is completely integrated into the intuitive trigger menu.
The Most Intuitive Decode
Patented software algorithms deconstruct the waveform into protocol decode information, then overlay the decoded data on the waveform. Depending on the time base setting or the amount of zoom, the decode information is condensed or expanded to better assist in understanding events. Various sections of the protocol are colorcoded to make it easy-to-understand. Communication Cycle Start and Error Frames are highlighted. The decode operation is fast—even with long acquisitions. The user can choose to decode into Hex or Binary formats.
Powerful Physical Layer Test
Quickly locate physical layer problems using powerful eye diagram mask test, watch the eye build up over time and use the error indicator to find mask violations and isolate problems. Mask testing combined with the built in automated FlexRay timing measurements let you know how your FlexRay physical layer is performing.
Extensive Triggering
Triggering on the complex FlexRay protocol is made easy with an intuitive interface and a wide range of trigger settings for all aspects of the protocol. Set up a simple TSS (Start) symbol trigger with a single button press or trigger on any part of a FlexRay frame including ID, Cycle Count, Cycle Repetition Factor and Frame Qualifier. FlexRay defined Symbols and Errors can also be incorporated into the trigger making it as simple or advanced as necessary. Conditional triggering can be set to trigger on a range of Frame Ids or Cycles.
Eye Diagram Mask Testing
Eye diagrams are an important part of testing many serial data standards and FlexRay is no different. Leveraging LeCroy's techniques developed with extremely fast serial data signals, the FlexRay eye diagram mask test overlays all the bits on FlexRay signal in an eye diagram with pass/fail mask testing. Tell the oscilloscope to stop on any mask violation and quickly locate the source of physical layer problems. By configuring the trigger for a specific Frame ID or range of Ids an eye diagram can be created to show only those Frames.
Physical Layer Measurements
Seeing the eye diagram gives good insight to your FlexRay system but measuring key timing parameters like Propagation Delay, Asymmetric Delay, Truncation and Jitter help you understand how signals propagate along the channel. Use LeCroy's statistics and histicons to understand the range of measurements on the FlexRay channel.
Convenient Table Display Summarizes Results
Turn your oscilloscope into a protocol analyzer with the Table display of decoded information. Custom configure the Table to display only the information you want and export Table data to an Excel file. Touch a message in the table and automatically zoom for detail.
Search and Zoom
ID or Data values can be quickly located by searching for a specific value. In a long acquisition, pressing NEXT advances the single byte to the byte right or left of the current message.
More Tools for Your Embedded System Test
LeCroy offers the same powerful triggering and intuitive decoding capabilities for I2C, SPI, UART, RS-232, Audiobus (I2S, LJ, RJ, TDM), CAN, LIN, FlexRay, MIL-STD-1553) signals. For complete embedded system testing, the MS-250 and MS-500 adds 18 or 36 digital channels to the digital oscilloscope allowing you to look at all your analog, digital, and serial data waveforms simultaneously with complete analog/digital cross pattern triggering.
关键词: FlexRay     触发     解码     物理     测试     软件包     t
