摘要:
This document explains how the EVM Application #1 generates a Pulse Width Modulated (PWM) signal and includes the following information. - An overview, background and methodology on what the EVM Application #1 is and how it works. - Listing of the three modules which must be configured - Formula for performing period register and compare register value calculations. - A figure that shows the difference between active high and active low polarity. - Assembly code for generating a pulse width modulated signal for the target system, the Texas Instruments (TI)(tm) TMS320F240 Evaluation Module (EVM).
文档:spra410.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=spra410
| 有奖活动 | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
