摘要:
This document describes the EVM Application #2, which generates an asymmetrical pulse width modulated (PWM) signal with a varying duty cycle. This application is implemented using C2xx Assembly code. Included in this document are: - Modules used - Input and output information - Background information on how the sine wave is implemented and generated - Code used with the target system, the Texas Instruments (TI)(tm) TMS320F240 Evaluation Module (EVM)
文档:spra411.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=spra411
