电子产品世界 » 论坛首页 » 企业专区 » TI » 【技术应用】使用TMS320F240实现无传感器速度控制无刷直流电机驱动器
2012-04-14 19:29:52     打赏
摘要:
The DSP Controller TMS320F240 from Texas Instruments is suitable for a wide range of motor drives. TMS320F240 provides a single chip solution by integrating on-chip not only a high computational power but also all the peripherals necessary for electric motor control. The present application note describes how a sensorless, speed controlled, brushless DC drive can be implemented using TMS320F240. This document shows that this sensorless solution is single chip and really cost effective in comparison with the sensored solution.
文档:bpra072.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=bpra072
关键词: 技术应用     使用     TMS320F240     实现     传感器
