电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » How Continuous Positive Airway Pressure
How Continuous Positive Airway Pressure (CPAP) Respiratory Ventilation Systems F
2012-04-14 19:45:11     打赏
How Continuous Positive Airway Pressure (CPAP) Respiratory Ventilation Systems Function
关键词: cpap, continuous positive airway pressure, block diagram, electrical components, respiratory ventilation
Abstract: This application note introduces how a continuous positive airway pressure (CPAP) ventilation system operates. The main subfunctions of CPAP respiratory ventilation include air-hose-environment sensing, compressor motor-drive feedback, motor-drive excitation, and a communication interface to a technician/doctor. These subfunctions are explained and a functional block diagram showing system components is also detailed.
 How Continuous Positive Airway Pressure (CPAP) Respiratory Ventilation Systems Function.pdf
关键词: Continuous     Positive     Airwa
