电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Thermal Noise Calculator Tutorial
2012-04-15 20:59:54     打赏
关键词: thermal noise, noise voltage, white spectral density, Johnson resistance, temperature, 1/f corner frequency, calculators, analog circuit design, HP50g programs, design tool, circuit analysis, signal test measurement, bandwidth, clock, jitter, analog referred
Abstract: The Thermal Noise Calculator (TNC) aids in the analysis of thermal noise found in resistors and other noise sources. The program is for use with an HP® 50g calculator or free PC emulator.
 Thermal Noise Calculator Tutorial.pdf
关键词: Thermal     Noise     Calculator
