关键词: ADC, DAC, Accuracy, Calculator, analog digital, design analysis, data converter, application circuits, DC accuracy, HP50g, Resolution, bits, PPM, INL, LSB, Analog Circuit Design, HP50g Programs, ACCU
Abstract: The Accuracy Calculator (ACCU) aids in the design and analysis of data-converter application circuits. It calculates the DC accuracy of an ideal data converter. The program is for use with a HP® 50g calculator or free PC emulator.
