电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Histogram Testing Determines DNL and INL
Histogram Testing Determines DNL and INL Errors
2012-04-16 21:12:20     打赏
关键词: code density test, histogram testing, ADC, high-speed data converter, integral nonlinearity, INL, differential nonlienarity, DNL, sample record, code count, bin width, probability density function, confidence level, hardware histogram
Abstract: Also called code density test, the histogram test approach helps determine nonlinearity parameters such as differential and integral nonlinearities (INL and DNL) in data converters. The following application note lends insight into the mathematical relationship between probability density function and various data converter specifications required to successfully complete the histogram test
 Histogram Testing Determines DNL and INL Errors.pdf
关键词: Histogram     Testing     Determi
