电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » pFET Linear Regulator Has Low Dropout Vo
pFET Linear Regulator Has Low Dropout Voltage
2012-04-17 23:49:24     打赏
关键词: P-FET, linear regulator, low dropout, p-channel, MOSFETs, amplifiers, comparator
P-channel MOSFETs (pFETs), though more expensive than pnp transistors, are free of the dissipation loss associated with base drive in a pnp circuit. pFETs also have a lower saturation voltage at light loads (Figure 1). In fact, the low RDS(ON), logic-level, p-channel power MOSFETs currently available can regulate 5V from a 5.1V battery!
 pFET Linear Regulator Has Low Dropout Voltage.pdf
关键词: Linear     Regulator     Dropout
