电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » EPOT Applications: Offset Adjustment in
EPOT Applications: Offset Adjustment in Op-Amp Circuits
2012-04-17 23:55:24     打赏
关键词: offset adjust, offset adjustment, op amp, nulling circuits, nulling op amps, DC offset voltage, opamps
Abstract: In some electronic systems, a DC offset voltage at the inputs will contribute a significant error to the output. This is especially true in high gain configurations. An offset adjustment circuit can be added to "null" out the offset voltage, making high gain stages practical even with significant input offset voltages found in op amp circuits.
 EPOT Applications  Offset Adjustment in Op-Amp Circuits.pdf
关键词: Applications     Offset     Adjus
