电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » How to Calculate the Operating Windows f
How to Calculate the Operating Windows for a Remote Antenna Current-Sense Amplif
2012-04-18 23:56:55     打赏
How to Calculate the Operating Windows for a Remote Antenna Current-Sense Amplifier and Switch
关键词: current sense amplifier, automotive antenna, antenna power supply, remote antenna power supply, remote antenna power, phantom power, radio antenna lna, active antenna detection, antenna diagnostics
Abstract: This application note helps designers choose the correct external components to ensure that automobile antenna-detection circuitry meets performance objectives. A calculator details how to specify the critical external components for the MAX16913/MAX16913A remote antenna current-sense amplifiers and switches. The calculator also determines the device's operational windows and analog output voltage accuracy. An example calculation is given.
 How to Calculate the Operating Windows for a Remote Antenna Current-Sense Amplifier and Switch.pdf
关键词: Calculate     Operating     Windo
