电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » USB-Powered High Precision Hi-Fi Phono P
USB-Powered High Precision Hi-Fi Phono Preamp
2012-04-19 12:31:55     打赏
关键词: low noise, op amp, phono, phonograph, RIAA, preamp, opamp, operational amplifiers, op amps, amplifier
Abstract: A quad, low-noise, op amp and LDO are used to build a stereo preamp with RIAA equalization to allow converting signals from a record player (phonograph) to a linear output for digitizing by computer sound cards etc.
 USB-Powered High Precision Hi-Fi Phono Preamp.pdf
关键词: USB-Powered     Precision     Hi-
