电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Low-Battery Indicator Is Low Cost, Highl
Low-Battery Indicator Is Low Cost, Highly Efficient, and Environmentally Friendl
2012-04-20 12:30:34     打赏
Low-Battery Indicator Is Low Cost, Highly Efficient, andEnvironmentally Friendly
关键词: comparator, low battery, LED, low cost, low power consumption, comparators
Abstract: This application note presents a circuit that uses a low-power CMOS comparator to provide an LED visual indication of a low-battery condition. This LBO (low-battery-indicator) is achieved by pulsing the LED at a low frequency and low duty cycle. The circuit accomplishes this without draining excessive battery current that can lead to permanent battery damage and, ultimately, hazardous waste disposal. This circuit also helps conserve battery current in the off cycle by placing the comparator in shutdown. Equations and circuit analysis are included for determining duty cycle and comparator trip points.
 Low-Battery Indicator Is Low Cost, Highly Efficient, and Environmentally Friendly.pdf
关键词: Low-Battery     Indicator     Hig
