电子产品世界 » 论坛首页 » 企业专区 » TI » 【应用手册】宽输入电压电池充电器使用SMBus的MSP430 MCU与BQ电量计
2012-04-21 19:50:50     打赏
摘要:
This application report describes a smart-battery charger reference design with a wide-input-voltage range. The reference design implements the System Management Bus (SMBus) protocol for communication between the MSP430 microcontroller and a SMBus-compatible battery fuel gauge. The MSP430 device interrogates the fuel gauge for voltage, current, and other parameters via SMBus. It then adjusts the pulse width modulation (PWM) duty-cycle output signals being fed to the dc/dc converter to deliver the power requested by the battery.
文档:slaa476a copy.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=slaa476a
关键词: 应用     手册     输入     电压     电池     充电器     使用     SMB
