关键词: overvoltage, overcurrent, over voltage current, protection, set, trip, point, circuit breaker, RS232, RS-232, rs 232, USB
Abstract: Using a current-sense amplifier, a high-side MOSFET driver, and a latching voltage monitor a circuit can be easily constructed that protects from overcurrent conditions and operates at voltages as high as 26V.
Overcurrent Monitor Operates up to 26V.pdf
