关键词: rail to rail, op amps, input, output, signal swings, beyond the rails, MOS, bi-polar, CMOS, P input pair, N common-mode, supply bias, current changes, sign magnitude, crossover, distortion, NPN, PNP, impedance, match phase, reversal, latch up, overdrive
Abstract: Railroads have had rail-to-rail components for years that were, in fact, nearly rail to rail. Op amps employ the same nearly rail-to-rail tradition. This application note discusses rail-to-rail op amps, and explains why some inputs and outputs can be less than, nearly, or slightly more than the power rails.
