Moving-Coil Meter Measures Low-Level Currents
关键词: moving-coil meter, high-side current amplifier, remote measurement, display drivers
Abstract: The MAX4172 IC substitutes a current amplifier for the shunt normally associated with a moving-coil meter. This circuit allows use of the moving-coil meter, even when the meter current is a large fraction of the current being measured
Moving-Coil Meter Measures Low-Level Currents.pdf
有奖活动 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
