电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 【应用手册】Test Methodology of Error Detectio
【应用手册】Test Methodology of Error Detection and Recovery using CRC in Altera FPGA
2012-04-30 10:17:03     打赏
【应用手册】Test Methodology of Error Detection and Recovery using CRC in Altera FPGA Devices
This application note describes how to use the enhanced error detection cyclic
redundancy check (CRC) feature in the Arria II, Stratix III, Stratix IV, Stratix V, and
later devices. It also describes the test methodology you can use when testing the
capability of this feature in the supported devices. Stratix V and later devices also
support error correction feature.
During FPGA configuration, the error detection CRC feature detects configuration
bitstream corruption when the bitstream is transferred from an external device into
the FPGA. In user mode, the error detection CRC feature detects a single event upset
(SEU) and determines the error type and location. In addition, Stratix V and later
devices support internal scrubbing, an ability to correct errors detected in user mode.an539.pdf
关键词: 应用     手册     Methodology     Error     D
