The IBIS Algorithmic Modeling Interface (IBIS-AMI) was developed to enable fast, accurate statistical and time-domain simulation of high-speed channels. It combines the ease of use and speed of standard IBIS signal integrity analysis with advanced communications analysis techniques.
xapp358.pdf
共1条
SerDes Channel Simulation in FPGAs Using IBIS-AMI
关键词: SerDes Channel Simulation
共1条
