In embedded systems, designers can reduce component count and increase flexibility by using a microprocessor to configure an FPGA. C code illustrates the use of either Slave Serial or SelectMAP mode. CPLD design files illustrate a synchronous interface between processor and FPGA.
xapp502.pdf
共1条
ing a Microprocessor to Configure Xilinx FPGAs via Slave Serial or SelectMAP Mod
关键词: Microprocessor Configure
共1条
